Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
LCD Screen is Cracked
The screen has a crack in it.
Cracked Your LCD Screen by Dropping the Camera
If your camera turns on as normal and the only problem is that the screen is cracked, follow this repair guide to fix your LCD screen.
LCD Screen Will Not Show Display
When you turn the camera on but the screen is black.
Camera is Dead
Make sure the battery is charged. If it isn't, plug the camera in and wait until it is fully charged.
LCD Screen is Broken
Make sure the camera is turned on. If the screen still does not show the display, follow this repair guide.
Camera Won’t Power On
You flip the power switch to on and nothing happens.
Battery is Dead
The battery might need to be charged. Plug the camera in and let it charge completely. Then try to power on again by pushing the power button.
Screen Problem
If the camera will extend its lense and can light up, but the screen is black, there might be a screen problem. Please refer to the LCD Screen Will Not Show Display.
Cracked Camera Lens
The camera lens has a crack in it.
Dropped Your Camera and Broke the Lens
If the lens is cracked, refer to this replacement guide.
Flash Isn't Firing
When a picture is taken, the flash won't go off.
Flash is on Auto
If the flash is on automatic mode, then the camera determines if the flash goes off or not based on the lighting. Make sure to set flash to on, not auto.
Flash is Broken
If the flash won't go off, and you've checked to make sure it's on, the bulb is broken. Please refer to this replacement guide.
2 Comments
Flap door on bottom of camera will not lock in place. What to do to repair it? It constantly hangs open, otherwise the camera is a “workhorse”….
scubacuba393 - Reply
When I turn on my Lumix, it asks me to set the date and time, but the screen then says system error (zoom). How do I fix that.
Kate Nagelkirk - Reply
