Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Playstation 3 Super Slim Won't Start
Your Playstation 3 Super Slim does not start up correctly.
Power Surge Damage
If the PS3 stopped starting up after a power surge or shortage, the device may have been damaged and will need a repair.
Incorrect Power Requirements
Check to make sure your PS3 model is made for your country. If it is made for a different country or region, it may have different power specifications.
Damaged Files
Enter Safe Mode by holding down the power button until you hear three beeps. Select "Restore File System." This will attempt to repair any damaged files saved onto the hard drive that may be causing the issue.
PS3 System Needs to be Restored
Enter Safe Mode by holding down the power button until you hear three beeps. Select "Restore PS3 System." This will perform a factory reset.
NOTE: You may want to back up your PS3 on a removable storage device before performing this last step, since this option will delete all data on the PS3 to revert it to it's factory settings.
If this last option does not work, your device may need a repair.
Defective Power Supply Unit (PSU)
If your PS3 shuts down after 10 seconds, there is a hardware issue with the PSU that cannot be resolved. The device will need a repair.
Playstation 3 Super Slim Freezes
The Playstation freezes on the XMB.
Damaged Files
Turn off your PS3. Enter Safe Mode by holding down the power button until you hear three beeps. Select "Restore File System." This will attempt to repair any damaged files saved onto the hard drive that may be causing the issue.
Turn off your PS3. Enter Safe Mode by holding down the power button until you hear three beeps. Select "Restore PS3 System." This will perform a factory reset.
NOTE: You may want to back up your PS3 on an external memory before performing this last step, since this option will delete all data on the device to revert it to it's factory settings.
Playstation 3 Super Slim Won't Read Discs
The optical drive of the Playstation 3 Super Slim is not working
Dirty Disc
Your disc maybe dirty. Insert a different disc to see if the issue exists across multiple discs. If the device reads this disc, clean the original one, then reinsert it into the Playstation 3 Super Slim.
Damaged Files
If this last option does not work, the laser lens on your device may need to be replaced or repaired.
Playstation 3 Super Slim Won't Connect to the Internet
General Network Troubleshooting
Poor Connectivity
Navigate with the XMB to Setting -> Network -> Test Connection. Any network connection issues should come up with an option to troubleshoot.
Faulty Network Devices
Turn off and unplug all network devices, including any wireless access points, modems, and routers. Leave these unplugged for two minutes. Then, turn them back on, and wait for them to cycle through their startup. Once the internet is back up, try connecting only the Playstation 3 Super Slim to the network.
Poor Internet Connection
Test to see if your home network is working properly by connecting from a computer. If it is not, you will need to contact your internet service provider to resolve the issue.
Necessary Ports are Closed
If you can connect to the internet but not PSN, you may need to open ports in your modem's settings. The ports that are needed open are TCP: 80, 443, 3478, 3479, 3480, 5223, 8080 and UDP: 3478, 3479.
Filtered MAC Address
If you have a modem that "filters" all MAC addresses, you will need to manually enter the PS3's MAC address as an allowed device. Your PS3's MAC address can be found as follows: go to the XMB home menu -> Settings -> System Settings and press the X button. Scroll until you see System Information and press the X Button.
Playstation 3 Super Slim is Not Displaying Correctly
General problems with the display of a Playstation 3 Super Slim.
Loose HDMI / Display Cable
Make sure that the display cable is connected properly.
Incorrect Display resolution
Check the display settings on your Playstation 3 Super Slim . From your XMB, go to Settings -> Display. Check that the correct resolution is selected.
PS3 is Not Recognizing Connected Devices
Restarting the system will allow the system to reidentify the connected devices.
Hard Disk Drive (HDD) Failure
Hard drive is not allowing system to boot or correct save files
Damaged Files
Faulty Hard Disk Drive (HDD)
A comprehensive guide of how to replace the current HDD with a new working one can be found at Playstation 3 Super Slim HDD Replacement
NOTE: To remove the HDD bay cover, do not attempt to pry it off as the guide says, instead, slide the cover towards the back of the device, then pull the cover off.
14 Comments
IN ENGLISH
Hello everyone . I have yesterday launched the update for my ps3 super slim pending That his finissisent I go take a shower . When I return my joystick gives more and HDMI Cable is well connected on the ps3 like on TV But television does well recognize the ps3 . I do not know what to do . Help me please.
IN FRENCH
bonjour a tous . hier j ai lance la mise a jour de ma ps3 super slim en attendant Que sa finissisent je suis aller Prendre une douche . Quand je reviens ma manette ne donne en plus et le câble hdmi is bien brancher sur la ps3 Comme sur la TV Mais la télévision ne reconnait ainsi la ps3 . je sais pas quoi faire . aidez moi sil vous plait
karim - Reply
Guys! I replaced my single lens laser drive deck. It reads discs and mounts but fails install and the system goes black with 3 beeps, green light stays on! Help!!
Robert S - Reply
Guys my superslim 500gb doesn't have the install packages option pliz help
Allan Dean - Reply
my issue, which I have not found a solution anywhere, is the system hard freezes after about an hour to hour and a half of continuously being powered on, doesn’t matter what game or if I am in the home screen. System was bought new, recently. I have restored the system, I have factory reset the system, the discs aren’t dirty.
bryce - Reply
I got a bad vibration in my PS3 super slim. It only gets bad when the it is getting hot. I just cleaned it and not sure what is wrong.
Alex Spencer - Reply
