Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Sound Failure
The projector will not produce sound.
Cable connection is broken
Check your computer or video source to ensure that the volume is cranked up and the audio output is set to the appropriate source. If the speaker does not produce sound. Consider purchasing a replacement connecting wire.
No power
Ensure every cable is plugged in and that it is compatible with each power source. If there is no sound, it could also be that the power source is broken and not providing enough power to the sound box.
Bluetooth needs to be powered off
Please make sure that you do not select Bluetooth Receiver status on the Bluetooth Setting page when utilizing the Airplay/ScreenMirroring function wirelessly. Click the settings button. Bluetooth: Press OK to turn on and off Bluetooth.
Light Bulb Switches Off
The lightbulb turns off after a period of time.
Loose power connector
Ensure that the power cable is properly connected to both the projector and the electrical outlet. If you find a connection that is loose, gently insert and secure the plug. Avoid using too much force, as this can harm the port or the plug. Plugging in another device will check that the power outlet is working properly. This easy test will help you establish whether the power source is the source of the problem. If the projector is linked to an extension cord, ensure that it is in good condition. Inspect the wire for apparent corrosion or deteriorating as this might result in power outages.
Overheating
Many projectors feature temperature controls, which cause the projector to shut off if it overheats. Make that the projector is in a well-ventilated area, away from other heat-producing objects. Consider using a fan to help cool the room down.
Dusty filters
If your light keeps shutting off. This could be due to dust and dirt accumulation in the filters. Locate the filters using this ++guide++.
No Image Projected
The projector fails to show an image.
Loose display connector
Make sure the power cable is properly connected and is secured properly in order to supply power to the projector’s lamp. Additionally, the projector turns itself off after a certain period of time of inactivity, if this occurs simply press the power button and it will resume projecting images.
Device not paired via bluetooth
Ensure that both the projector and device are connected and close in range. If devices are close in range, make sure your device has bluetooth connectivity turned on in order to connect.
Loose power cable
If your device is connected via USB or HDMI, make sure both the ends of cables are securely connected to their respective ports.
Image Brightness is Faded
The quality of the brightness is dim.
Dusty filters
If your projector brightness is faded. This could be due to dust and dirt accumulation in the filters. Locate the filters using this ++guide++.
Dead bulb
The ambient light in the room may be the source of this. If not, it's likely that the lamp needs to be replaced (bulb).
Dirty glass cover
A dirty glass cover could be another factor contributing to the decreased brightness of your image. Remove this covering and clean out the dust and dirt using soap and water. Do not use rubbing alcohol.
Cloudy or Blocked Images
The projectors images are distorted or blocked.
Dirty lens
If your projector is showing cloudy images it could be because the lens is dirty, take it off and clean it.
Focus settings need to be adjusted
If the projector is showing blurry images the focus could be wrong. Adjust it to make the images clearer here is a ++guide++ on how to change the focus.
Image settings need to be adjusted
If the projector is showing blurry images then it could be that your settings are wrong. Certain settings like the resolution change the quality of the images which mess with the images. Here is a ++guide++ on how to change the settings.
3 Comments
Where can i get a heat insulation glass for my Roconia Q6 projector?
Alberto Lugo - Reply
I have a picture how the image looks but I can't post it on this email.
Help! I can’t get the image to fit the screen! During previews I have a full screen but when the movie comes on I have a thin slice of picture down the middle of the screen.
Guyfrechette - Reply
