Unlisted
This wiki will not appear in search results, but can still be viewed by anyone!
RepairManifestoTranslations est
REPAIR MANIFESTO
Parandaja manifest
We hold these truths to be self-evident
Meie jaoks on see iseenesestmõistetav:
If you can't fix it, you don't own it.
Kui sa ei saa seda parandada, siis ei kuulu see sulle.
REPAIR IS BETTER THAN RECYCLING
Parandamine on parem kui taaskäitlemine.
Making our things last longer is both more efficient and more cost-effective than mining them for raw materials.
Oma asjade eluea pikendamine on odavam ja mõistlikum kui nendest tooraine eraldamine.
REPAIR SAVES YOU MONEY
Parandamine säästab su raha
Fixing things is often free, and usually cheaper than replacing them. Doing the repair yourself saves you money.
Asjade parandamine on tihti tasuta ja odavam kui uue ostmine. Ise parandamine on säästlikum.
REPAIR TEACHES ENGINEERING
Parandamine õpetab elektroonikat.
The best way to find out how something works is to take it apart.
Parim viis teada saada, kuidas miski töötab, on see koost võtta.
REPAIR SAVES THE PLANET
Parandamine säästab keskkonda.
Earth has limited resources. Eventually we will run out. The best way to be efficient is to reuse what we already have.
Inimkonna ressursid on piiratud. Ühel hetkel saavad need otsa. Parim viis loodust säästa on olemasoleva ära kasutamine.
REPAIR CONNECTS PEOPLE AND THINGS
Parandamine lähendab inimesi asjadega.
REPAIR IS WAR ON ENTROPY
Parandamine on sõda entroopia vastu.
REPAIR IS SUSTAINABLE
Parandamine on jätkusuutlik.
WE HAVE THE RIGHT:
Meil on õigus:
TO DEVICES THAT CAN BE OPENED
Seadmetele, mida saab lahti võtta.
TO REPAIR DOCUMENTATION FOR EVERYTHING
Kõigi seadmete parandamisjuhenditele.
TO REPAIR THINGS IN THE PRIVACY OF OUR OWN HOMES
Parandada asju oma koduseinte vahel.
TO ERROR CODES & WIRING DIAGRAMS
Veateadetele ja elektriskeemidele.
TO CHOOSE OUR OWN REPAIR TECHNICIAN
Valida endale ise tehnik
TO NON-PROPRIETARY FASTENERS
Standarditud kruvidele
TO REMOVE 'DO NOT REMOVE' STICKERS
Eemaldada "Mitte eemaldada" kleepse
TO REPLACE ANY & ALL CONSUMABLES OURSELVES
Kõiki kuluosasid ise vahetada
TO TROUBLESHOOTING INSTRUCTIONS & FLOWCHARTS
Veaotsimisjuhistele ja plokkskeemidele
TO AVAILABLE, REASONABLY PRICED SERVICE PARTS
Mõistliku hinnaga varuosade kättesaadavusele
BECAUSE REPAIR
Sest parandamine
IS INDEPENDENCE
On sõltumatus
SAVES MONEY & RESOURCES
Säästab raha ja materjali
REQUIRES CREATIVITY
Vajab loovust
MAKES CONSUMERS INTO DISTRIBUTORS
Muudab passiivsed tarbijad aktiivseks
INSPIRES PRIDE IN OWNERSHIP
Paneb uhkust tundma oma seadme üle
JOIN THE REVOLUTION WITH IFIXIT.COM
Liitu revolutsiooniga - ifixit.com
0 Comments
