Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The screen flickers when turned on
When the phone turns on the screen flickers on and off.
Some apps are causing the problem
If the screen keeps flickering, it could be caused by an app that was downloaded. The app is causing inconsistencies in the system which is causing the problem. Restart the phone in safe mode by:
1. Press and hold the Power button (located on the right) until Phone options is displayed then release.
2. Select and hold Power off until the Reboot to Safe Mode prompt appears then release.
3. Tap RESTART.
4. Upon restart, Safe mode appears in the lower left of the unlock/home screen.
Once in Safe mode apps can still be used and if the problem stops then the cause is a third party app that needs to be uninstalled. To uninstall the an app:
1.From any Home screen, tap the Apps icon.
2. Tap Settings.
3. Tap Applications.
4. Tap Application manager.
5. Tap the suspected application
6. Tap Uninstall.
7. Tap Uninstall again to confirm.
Water damage
If the phone was dropped in some water, then water could have entered the phone and the water that is trapped in the phone is causing the problem.
Physical damage
The phone has physical damage from being dropped and the screen as a whole would need replacing.
Won't charge
The phone won't charge.
Check the charging cable
The problem may not be with the phone at all but with the charging cable. Try another cable to see if the problem persists.
Damaged charging port
Check the phone’s charging port for lint, debris, corrosion and bent pins. For lint and debris, you can try fishing them out or try blasting compressed air to get rid of them. As to the corrosion, to clean it out with an alcohol or anything that dries out after a few seconds. If it happens a pin or two is bent, try to straighten it out using a pair of tweezers. (Note be very careful not to damage them.)
The device has connection issues
Your device is not recognizing any wireless signal near it.
Cache partition on phone is full
It is possible that the cache partition of the device is full, making the device clustered and outdated. So go to the recovery menu and wipe cache partition.
1. Turn off the device.
2. Press and hold the Volume Up key and the Home key, then press and hold the Power key.
3. When the device logo screen displays, release only the Power key
4. When the Android logo displays, release all keys ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
5. Press the Volume down key several times key to highlight 'wipe cache partition.'
6. Press the Power key to select.
7. Press the Volume down key to highlight 'yes' an press the Power key to select.
8. When the wipe cache partition is complete, 'Reboot system now' is highlighted.
9. Press the Power key to restart the device.
Applications are not up to date
It’s possible that your device may not be detecting any signal around it because the applications on the device might be out of date. Make sure you update all applications that are able to be updated, also make sure to power down your phone and then turn it back on.
Camera Issues
‘‘The device ‘s camera fails when it its launched.’’
Cache and Camera app data for full
This procedure will reset the app itself as it deletes its cache and data along with your settings and preferences. (Note: none of your pictures or videos will be deleted when you do this and only the camera settings will be reset.)
- From any Home screen, tap the Apps icon.
- Tap Settings.
- Tap Applications.
- Tap Application manager.
- Tap Camera.
- Tap Storage.
- Tap Clear data and then tap OK.
- Tap Clear cache.
An app is causing the problem
‘‘A third party app is causing the problem.‘’
There are times when third-party apps cause this kind of problem and when it happens, disable them and see if the problem still happens and there’s no other way to do that than booting the device in safe mode:
- Press and hold the Power button (located on the right) until Phone options is displayed then release.
- Select and hold Power off until the Reboot to Safe Mode prompt appears then release.
- Tap RESTART. Note: This restart process may take up to one minute to complete.
- Upon restart, Safe mode appears in the lower left of the unlock/home screen.
After successfully booting up the device in safe mode, try to open the camera app and see if the error or the warning still pops up, if it doesn’t, then you just have to find the third-party app that causes the camera to crash and uninstall it.
This is how you uninstall an app on the Galaxy J7 V:
- Tap Settings.
- Tap Applications.
- Tap the desired application
- Tap Uninstall.
- Tap Uninstall again to confirm.
The Device Won’t Power Up
‘‘Your device won’t turn on.’’
Lack of Power
The simplest solution is to put the device to charge for at least 15-20 minutes. Once charged, attempt to power on by pressing and holding the power button for approximately 10-15 seconds.
Soft Reset Necessary
Try a soft reset of the device to see if the phone will recover. Simply, remove the battery and replace after 10 seconds.
Faulty Charging Cable
If you have another Samsung device or a third party Android phone, try to use its USB cable and charger and see if that will charge your device. Many times, a bad charging cable or adapter could be the reason your device won’t charge.
Defective Battery
Replacing the battery is simple. Remove the back cover of the phone and simply take the battery out. If you know someone with the same phone, try using the battery from that phone and see if your phone will power on. If you don’t have access to another J7 battery, try to visit local phone stores and see if they will let you use a working J7 battery. Avoid buying a new battery outright as you don’t have a way of knowing conclusively if it’s a battery issue.
Defective Charging Port
A sign that a charging port may be broken is a bent pin inside the socket. If you have access to a magnifying tool, use that to inspect the socket. Any dirt or bent pin can be the reason why the phone no longer charges the battery. Avoid sticking something inside the port as that can further damage other pins. If the port is damaged, you should consult a professional on how to address it.
4 Comments
My wifi keeps disconnecting every 5 mins
Jesse Jones - Reply Share
My Galaxy J7 is unable to receive calls in my apartment. Outside it works just fine. Any suggestions?
JPS
Joe Sullivan - Reply Share
Phone charger shuts off, Says “phone temperature is too low” even when it not.
STEVEN - Reply Share
My phone can not make a call or recetve one.l.
Lawrence Floyd - Reply Share
