Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The tape doesn’t eject
When the eject button is pressed, the cassette does not come out.
The battery is dead
Replace the current battery with a charged battery. For more information on battery replacement, view our guide on replacing the battery.
The power connection is not properly made
Connect the AC power adaptor into the DC IN 9.6 V jack near the bottom of the Betamovie. Connect an AC power adaptor into a wall socket or a car battery cord into a cigarette lighter socket firmly. Turn on the AC power adapter.
Insert a battery pack if there is none inserted.
The camera won’t white balance correctly
The white balance cannot be adjusted and the “W” lamp in the viewfinder stays on.
Light is insufficient
If the "L" light is still lit, it means the lighting is inadequate. Add lighting to the filming environment or change locations.
Camera is under certain types of light
In the presence of neon lights or tunnel lights, the "W" lamp will remain on. A recording can still be made because the white balance is almost properly adjusted due to the position of the FILTER selector.
The camera won’t power on
When the power button is pressed, the standby light does not turn on.
There is no cassette inserted
Insert a Betamax cassette. The camera will not power on if there is no cassette inserted. Insert a cassette with the tape viewing window on the right.
The safety tab for the cassette is removed
Cover the hole left by the safety tab with a piece of plastic tape or insert a cassette with a safety tab.
The tape is at its end
Eject the cassette and insert a new cassette with the round window facing to the right pressing firmly into place. Press the left side of the cassette compartment lid closed. Rewind the tape on a VCR or replace the cassette.
The auto-focus won’t work
The auto-focus function does not work when the camera is in recording mode.
The FOCUS switch is not set to AUTO
Set the FOCUS switch to AUTO. The FOCUS switch is located on the left side of the camera below the lens.
The lens is foggy or dirty
Clean the lens. If the lens cannot be cleaned, view our replacement guide for a lens replacement.
The shooting conditions are not suitable for autofocus.
Make necessary lighting adjustments or choose a new filming environment. The autofocus won't work correctly in shooting conditions with insufficient light or with subjects that are difficult to focus on.
The tape does not run when the REC START/STOP button is pressed
When the record start/stop button is pressed, the tape will not run.
The tape is stuck to the head drum
Eject the cassette and insert it again. The eject button will not work if the camera is off.
Rewind the tape on a VCR.
Replace with a new cassette. Eject the current cassette and insert a new cassette with the round window facing to the right. Push the left side of the cassette compartment down to close.
0 Comments
