Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Burner won't heat up
The temperature of the burner is not increasing regardless of the setting of the dial.
Power source is not providing any power
Make sure the hot plate is plugged in. Check to see if the red indicator light (ON) is on when dial is not set to OFF. If indicator light does not turn on, then check your outlet for power using another (working) device. If the outlet is working properly, then your power source is not the problem.
The hot plate is not properly cleaned
Make sure the hot plate is clean and remove residue or gunk. (Make sure the burner dial is set to OFF when cleaning.)
If the hot plate is properly clean, set dial to highest setting and check if the hot plate is heating properly. Do not use your hands. It is recommended to hover your hand over hot plate or try to boil a pot of water.
The setting are not working on the knob
Remove knob: with one hand on the knob and one hand equipped with a spudger, simultaneously pull the knob outward and insert spudger, using the flat edge, in behind the knob. This will allow the knob to be pulled free. Check for damages on the knob causing it to not work properly and look into buying a replacement part.
Burner is giving off fumes
Burner is giving off a gaseous foul odor
The exhaust fans are not clean
Begin by cleaning the exterior of the underside of the burner and the vents with a cotton swab or damp cloth.
The chemicals within the device need to be burned off
While the device is off, clean the exterior with water and dry. Then allow the burner to run on the highest setting for 5 minutes. Repeat as necessary until no more odor is present.
The chemicals around the hot plate need to be burned off
Remove the hot plate using this guide, Disassembling Waring Pro SB30 Hot plate. Clean and dry the hot plate and reassemble.
The plastic sides of the burner are warping
The plastic sides are melting in some fashion.
The plastic sides may have been warped due to the use of a pot larger than the burner
The sides can be taken off using this guide, Disassembling Waring Pro SB30 Plastic sides, but replacement sides would need to be purchased for replacement.
Note: In the future, do not use pots larger than the burner because the larger pot is conducting the heat onto the plastics sides, therefore causing the deformation.
The lights are not working correctly
If the device is heating properly, but the lights are not working.
The lights are out of place
Use this guide to remove the back panel of the burner, Disassembling Waring Pro SB30 Back panel, and locate where the indicator lights are. Make sure that they are properly in their plastic shells.
The indicator lights need replacing
Use this guide to remove the indicator lights from their plastic shells, Disassembling Waring pro SB30 Indicator Lights. You will then need to remove the lights and solder replacement lights in their place.
The burner is not level or even
The burner not being level or even may cause spills of hot substances.
The plastic legs or rubber stoppers are out of place or damaged
If the plastic legs or rubber stoppers are out of place, use this guide to remove them and re-position them: Disassembling Waring Pro SB30 Plastic leg and rubber stoppers. If the rubber stoppers are damaged look into replacing.
0 Comments
