Whirlpool Dishwasher Not Draining
Jeff Suovanen and 1 contributor
Last updated on
Dishwasher not draining, or draining too slowly? Whirlpool dishwashers are susceptible to a range of issues that can cause this problem—some simple to fix, some not. Check the following items in order to identify and correct the issue.
Causes
Check to make sure the last wash cycle completed properly—if your dishwasher has a “Clean” indicator light, it should be illuminated. If not, the wash cycle may have been interrupted. Close the door and press the Start button.
2
Try running the garbage disposal (if you have one)—if it shares the same drain as the dishwasher, this can prevent the dishwasher from draining.
3
Check the drain hose that runs from the bottom of your dishwasher to the drain pipe (usually below the sink). Make sure it’s not pinched or kinked. If necessary, replace it with a new hose.
4
Remove the drain hose end from the nipple it's connected to below the sink or disposal, put the end in a bucket, then fill and drain the dishwasher to see if a garbage clog will simply blow out. If that doesn't work, but you see a small dribble of water, you may have to pull the dishwasher out and remove the drain hose in order clean it out or replace it. (Remember, there's still water in the unit—so put a drain pan under it before removing the hose.)
5
If you recently installed a new garbage disposal, make sure the knock-out plug was removed. It's right inside the nipple where the drain hose from the dishwasher attaches to the disposal. If it’s not removed, the dishwasher can’t drain properly.
6
The check valve is located underneath the dishwasher, just before the drain hose. It’s a one-way valve, allowing water to drain but not return to the dishwasher. Remove the drain hose from the dishwasher (remembering to put a drain pan underneath) and check to make sure the valve is clean and opens correctly.
7
If there are no obstructions to the drain system and your dishwasher is still filling with water, you may need to replace the pump.
View statistics:
Past 24 Hours:
7
Past 7 Days:
39
Past 30 Days:
182
All Time:
56,004
