iPod won't turn on
No matter what you do, you can't get your iPod to turn on.
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input on the click wheel and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, it must be replaced. We sell replacement batteries, but replacing the battery is very difficult (it requires soldering) and requires a new rear panel. (The nature of the clips on the rear panel prevent reattachment once the rear panel is removed.) If you are not confident in your soldering abilities, you should probably purchase a new iPod.
Bad display
It is possible that it appears nothing is happening because the display is bad. If nothing is visible, or just a white screen shows up, it is possible the display is bad and must be replaced. Replacement also requires a new rear panel. (The nature of the clips on the rear panel prevent reattachment once the rear panel is removed.)
Bad click wheel
If absolutely nothing happens, it is possible that your iPod is not receiving your instructions because the click wheel is bad. The click wheel on this model is adhered to the front panel. Therefore, to fix this problem, you need to replace the front panel. Replacement also requires a new rear panel. (The nature of the clips on the rear panel prevent reattachment once the rear panel is removed.) It may be more cost/time effective at this point to purchase a new iPod.
Bad logic board
If your iPod does nothing when plugged into a computer, the problem most likely lies in the logic board. We offer the following logic boards: 4 GB, and 8 GB. However, due to the materials needed (replacement also requires a new rear panel) and cost/time, you should probably purchase a new iPod at this point.
No audio or distorted audio
Your iPod turns on and appears to work, but when you plug in headphones or speakers, the audio doesn't play properly.
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPod with another set of headphones or speakers just to make sure that the problem is with the iPod.
Bad audio jack
The most likely cause of audio output problems on iPods is a bad audio-out jack. This jack is permanently affixed to the logic board. We offer the following logic boards: 4 GB, and 8 GB. However, due to the materials needed (replacement also requires a new rear panel) and cost/time, you should probably purchase a new iPod at this point.
Restore icon on startup
Your iPod displays the text "Use iTunes to restore" on startup
Corrupted software
Sometimes, a reset and restore will fix a sad iPod. Connect your iPod to your computer and use iTunes to restore the iPod. Restoring the iPod will erase everything on it, so make sure everything on the iPod is stored elsewhere prior to restoring. Sometimes it may be necessary to restore the iPod several times before it works properly. If you are unable to restore your iPod using iTunes, you can hard reset your iPod. iPod Nanos can be hard reset by booting while holding the menu and play/pause buttons. This should result in a quick dark screen followed by the standard Apple boot graphic.
Bad logic board
If restoring the iPod didn't work, the sad iPod is likely caused by a problem with the logic board. There's not much to troubleshoot here. Basically, the only option is to replace the logic board (4 GB, and 8 GB). However, due to the materials needed (replacement also requires a new rear panel) and cost/time, you should probably purchase a new iPod at this point.
Folder icon appears on startup
The iPod displays an image of a folder when turned on.
Bad memory
One of the nice things about iPod Nanos is that their flash memory is nearly impervious to damage from dropping the iPod. Unfortunately, this also means that the memory is soldered to the logic board. Therefore, you must replace the logic board (4 GB, and 8 GB). However, due to the materials needed (replacement also requires a new rear panel) and cost/time, you should probably invest in a new iPod at this point.
iPod doesn't boot past Apple logo
The iPod either boots to an Apple logo and freezes or continuously reboots.
Bad logic board
This is likely the cause, and you must replace the logic board (4 GB, and 8 GB). However, due to the materials needed (replacement also requires a new rear panel) and cost/time, you should probably purchase a new iPod at this point.
23 Comments
I dont know whats wrong with my i pod it wont turn on unless its plugged into a dock or in the computer, right when i unplug it, it turns off for good!
lindsay - Reply
my ipod model a1236 is locked how to un lock it
anthony -
my douther locked my ipod model a1236 how can i unlock it
anthony -
lindsay, since your iPod works when connected to a power source but then shuts off once disconnected the problem is likely a dead battery.
Megan - Reply
I accidently washed my iPod nano (forgot it was in a pocket of something). The iPod works as far as music and battery and all that. The only problem is the backlight wont turn on.... if I got a new screen 'kit' and the back piece and replaced it all would that fix it? Im not sure b/c the backlight "thing" is probably something else right? I took it to the store and of course they couldnt fix it I would have to buy an entire new one.
Also, what about engraving that is on the back of the back piece?
Thanks
Tabitha
tmfritz - Reply
