Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device does not turn on
Robot does not show any signs of activity when the power button is pressed.
Dead battery
The battery may have run out of charge. Remove the battery and place it in the charging adapter. Plug the adapter into the wall and wait about two hours until the blinking orange light turns green. Then place the battery back in the slot on the robot. To remove the battery, refer to this guide.
Faulty battery
A faulty battery can also prevent the robot from turning on. If the battery is charged and the robot still does not turn on, then the battery is faulty. Replace the battery with this guide.
Faulty adapter
The robot may not turn on because the adapter is not charging the battery. If the light on the adapter does not turn on when plugged into the wall, then the adapter is faulty. Consider finding a replacement online.
Device does not move in a straight line
The robot does not move forwards when turned on.
Wheels covered in debris
Debris that gathers in the wheels can prevent the robot from moving correctly. To clean the wheels of debris, turn the robot upside down rotate each wheel. If any debris is visible, gently pull it out of the wheel.
Mop pad separating from attachment card
The attachment card holds the mop pad and is located in front of the wheels. If the pad is worn out, it could separate from the attachment card and inhibit the movement of the robot. Verify that this is the problem by looking at the mop pad. If the pad is particularly worn near the wheels, the mop pad should be swapped with a new one using this guide.
Tire tread not firmly attached
Loose tire tread could inhibit the motion of the robot. To determine if the tire tread is loose, use your thumb to push the tread outward and away from the wheel. If the tread comes off, the wheel should be replaced by following this guide.
Device is leaking
Water does not stay in the reservoir.
Overfilled water tank
Check to ensure the water tank was filled to just below the tank cap. There should be enough room for the tank cap to close completely without forcing water out of the tank. If not, remove the tank cap and pour out any excess water.
Faulty tank
If the tank is filled correctly, there may be a problem with the water tank itself. Inspect the tank by removing the filter (reference this guide). If the tank is damaged, replace it using this guide.
Device sprays dirty water
When cleaning, the robot sprays dirty water.
Dirty filter
If there is residue in the filter, the robot may spray dirty water. To clean the filter, first remove it from the robot. Then remove any visible debris. Afterwards, rinse it under warm water. For instructions on how to remove and reinstall the filter, follow this guide.
Residue in tank
If the robot still sprays dirty water, there may be residue in the tank. To clean the tank, remove it from the robot and rinse it with soapy water. For instructions on how to remove and reinstall the tank, follow this guide.
Device does not spray water
When cleaning, the device does not spray water out of the nozzle.
Empty water tank
The robot has an internal tank that holds water. If this tank is empty, then the robot will not spray water. The lid of the tank is located on top of the robot under the handle. Refill the tank, and try cleaning again.
Faulty spray nozzle
The spray nozzle is the piece that ejects water. If the water tank is full, then the nozzle may be faulty. The nozzle can be replaced using this guide.
18 Comments
My Brava 241 is not cleaning properly, it takes only one round and stops without completing its job.
whenever I restart it to complete mopping, it doesn't work. it switches off after second pressing of start button.
Pankaj Srivastava - Reply Share
My battery seems to charge and green light comes on but when placed into irobot no lights come on machine. Battery has been replaced a while ago when green light did not come on?
vivienne - Reply Share
My brava jet240 will not move.. wheels seem to jump then will not go. I have cleaned the wheels but nothing changes.
ashmoj1942 - Reply Share
My braavajet turns on it won't move. I have cleaned and done everything the trouble shooting has suggested. What else can I try
slt170 - Reply Share
Hello, I was wondering if you managed to sort this problem. My iRobot braava has the same problem.
Linda - Share
