Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
uAttend bn6000 Troubleshooting
uAttend bn6000 Biometric Fingerprint LAN Time Clock
uAttend BN6000 Troubleshooting
This troubleshooting guide will help you find solution for common uAttend BN6000 problems.
Clock Has No Network Connection
The uAttend bn6000 is unable to connect to the network server.
uAttend is not plugged into the router
The uAttend time clock must be plugged directly into an internet router to ensure proper network connectivity. Make sure your internet connection is active and working properly
Router/Modem Issues
If the time clock is unable to connect to the network server, you may be experiencing problems with your modem or router. Turn off your router, wait 30 seconds, then turn back on. If problem persists, contact your internet service provider.
Clock Will Not Turn On
The time clock is not powering up properly for use.
AC Adapter is not plugged in properly
The AC adapter must be connected properly to the clock and also plugged into a 110VAC power source to operate properly. Check to make sure that both ends of the AC adapter are plugged in fully.
No Power Source
You must have a live 110VAC power supply to efficiently operate the clock. Check and make sure that unit is plugged in properly to a live power source.
Keyboard not responding
The keyboard is not registering the correct items when pressed.
Keyboard is dirty
The keyboard must be clean of debris in order to operate properly. Clean the keyboard with electronics cleaner and blow off excess debris with Air Duster.
System is Frozen
If the keyboard is clean and still not operating properly, turn clock off by unplugging, wait 30 seconds, and then plug clock back in to restart.
Keyboard is Faulty
If keyboard is still not responding after above steps, replacement of keyboard component may be necessary. keyboard Replacement Guide
Finger print scanner not reading properly
Failure to read fingerprint scan.
Finger is dirty
Finger must be wiped clean of dirt and debris for scanner to properly recognize finger print. Wipe with cleaning cloth and scan again.
Scanner screen is dirty
Scanner must be wiped clean of dirt and debris to recognize finger print properly. Wipe scanner screen with electronics cleaning cloth and scan again.
Improper finger placement
Finger must be placed in proper central position on screen in order to recognize fingerprint properly. Center finger on screen and scan again.
Fingerprint scanner is faulty
In the case that all of the above troubleshooting solutions don’t work, remove and replace fingerprint scanner screen. Fingerprint Replacement Guide
PIN unrecognized
PIN unrecognizable when entered.
Incorrect PIN number entered
Each employee is given a personal ID number which what be entered in paper sequence for proper time clock open it. Make sure proper PIN was entered.
User deleted
User must be added and registered to the user template in order to clock-in/clock-out properly. uAttend User Templates
Device factory reset
In the case that device was reset to factory settings, all user ID’s must be re-entered as new user templates. Device reset
1 Comment
The website can not find my account?
Paula lawson - Reply
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 24
All Time: 8,095
