Dell Inspiron 600M RAM Replacement
Taylor Woods
Taylor Woods and 5 other contributors
Last updated on January 28, 2014
5 - 10 minutes
Easy
Introduction
Go to step 1
Before removing the RAM you will need to remove your battery.
iFixit earns commission when you buy through these links.
  1. Dell Inspiron 600M RAM Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600M RAM Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600M RAM Replacement, Battery: step 1, image 3 of 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600M RAM Replacement, RAM: step 2, image 1 of 3 Dell Inspiron 600M RAM Replacement, RAM: step 2, image 2 of 3 Dell Inspiron 600M RAM Replacement, RAM: step 2, image 3 of 3
    • Remove the single screw securing the RAM compartment and pull up to reveal the RAM.
  3. Dell Inspiron 600M RAM Replacement: step 3, image 1 of 3 Dell Inspiron 600M RAM Replacement: step 3, image 2 of 3 Dell Inspiron 600M RAM Replacement: step 3, image 3 of 3
    • Push on the small white metal tabs on both sides of a module to unlock it.
    • The RAM should be stick out at approximately a 45 degree angle. Grasp the RAM by the sides and pull straight out to remove it.
    • If the RAM sticks slightly, wiggle it back and forth gently to loosen it.
Taylor Woods
113 Reputation
2 Guides authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 18
All Time: 4,022
