Motorola Krzr K1m Battery Replacement
Jennifer Hudiono
Jennifer Hudiono and 5 other contributors
Last updated on January 28, 2014
5 minutes
Very easy
Introduction
Go to step 1
This guide will show you how to detach the batter on the Motorola KRZR. It will give you instructions on how to disassemble the back cover of the KRZR in order to access the battery.
  1. Motorola Krzr K1m Battery Replacement, Battery: step 1, image 1 of 2 Motorola Krzr K1m Battery Replacement, Battery: step 1, image 2 of 2
    • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  2. Motorola Krzr K1m Battery Replacement: step 2, image 1 of 1
    • While pushing down on the silver tab, slide the back cover towards the silver tab.
    • Remove the back cover.
  3. Motorola Krzr K1m Battery Replacement: step 3, image 1 of 1
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Replace the old battery with the new battery.
    • Follow all of the steps to remove the battery in reverse order to reassemble.
Jennifer Hudiono
42 Reputation
4 Guides authored
Cal Poly, Team 11-1, Forte Winter 2010 Member of Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 5,664
