Levers will not stay down on my all clad toaster
How do I fix levers won’t stay down
If the electromagnet is causing the fault, then follow these instructions: Slider of toaster does not stay down - Repair
Hi,
The issue on your toaster can either be a broken heater element or an integrated circuit issue.
If you hold it down and the toaster heats up, it means that the problem is with your circuit or the actual electro-magnet, that should hold the lever down when it operates normally.
Unfortunately for both repairs you need to disassemble your toaster completely.
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 95
All Time: 1,110
