Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
How can I replace the motherboard of my iPhone 5s?
My iPhone 5s died on me and it's the motherboard. How can i change it? or where should I go to have it changed?
i bought it of ebay thinking it's a easy battery fix. well... it wasn't. Apple doesn't what to replace the phone because the find my iPhone app is still on in the device.
Any suggestions?
Score 11
1 Comment
Were you able to use it before?
by
Add a comment
Most Helpful Answer
The motherboard *IS* the phone. If you need a new motherboard, you need a new phone.
What exactly is the motherboard problem? One of the myths out there is that motherboard problem = certain doom. That is not always the case.
PS: If you've bought this phone on eBay and it is Find my iPhone/iCloud locked to someone's Apple ID that is not you, then it really is a cute paperweight.
Score 2
Add a comment
Hello,
You can absolutely replace the motherboard in your phone but it is only worth it if all the other components are functioning properly.
You will pretty much need to tear the phone down to get the motherboard out but it can easily be done by a professional, and replaced by a professional.
Your phone is not a total loss.
John Device Savers
Score 2
6 Comments:
do you know any one who could fix it?
by
yeah do you?
that would great
by
@JohnDeviceSaver my iPhone5s the lcd screen is not functioning but all are functioning I check with the repair shop they said the connector to the screen on the motherboard is spoil if I get that replaced will it affect my data on my phone ?
by
my phone complerty shut down it turns on but only the apple logo is on the screen so were do I get it fixed or is getting it fixed way too expenses please help
by
ok so no help
by
Show 1 more comment
Add a comment
You can remove find your iPhone on your PC. Log in to iCloud.com on your PC and find your device to remove.
Score 1
Add a comment
First, the motherboard/logic board contains all the information. Secondly, you can switch the motherboard/logic board if it's dead for a working one. If you're still under warranty and haven't repaired/opened the iPhone just take it to apple and they should replace it. I do also think the touch id/home button is unique to the logic board (not sure). If you do switch out the logic board make sure to log on to icloud.com, sign in and erase all data from the logic board you took out so your stuff won't be saved on it. Hope this helps.
Score 1
1 Comment:
I don't understand what do you mean by:
"If you do switch out the logic board make sure to log on to icloud.com, sign in and erase all data from the logic board you took out so your stuff won't be saved on it.".
Let's say you replaced old logic board that has old data on it with a new one with no data. You then suggest to log in to iCloud and erase all data from the old logic board? Why? What stuff won't be saved on what? Doesn't it mean that following your advice leads to loosing old data?
by
Add a comment
where can i get a new motherboard for my iphine5s
Score 1
1 Comment:
Where can I get the I phone 5s motherboard in India
by
Add a comment
If you want to replace the logic board you can use this guide: iPhone 5s Logic Board Replacement
Add a comment
sir i fone 6 puls ka borad chang ho sakta hai
Add a comment
I just changed the motherboard on an iPhone 5s and the phone keeps rebooting, does anyone now why?
Add a comment
Add your answer
John Smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 30,599
