Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
How can I make my tzumi dream vision controller connect to my phone
I had just gotten a new tzumi dream vision and I tried to connect the controller but it just won’t it crept showing me an error message saying to make sure it is on and in range. I have tried resetting and holding down the multifunction button but it won’t connect.
Score 9
5 Comments
Not strictly a solution but got my controller to pair by some button mashing which caused it to promote me for the pin. I entered 0000 and it paired immediately with my Samsung s8.
by
Errr ... where exactly do you enter the code??
by
It worked on gs7 I wish it in instructions thank you button master
by
It wont do that for my X
by
My x wont pair
by
Add a comment
Most Helpful Answer
I had this problem too. Fought with it for 4 days until I figured it out by being a button master lol. With IOS you have to hold down the @ button first, then while holding the @ button press and hold the power button. You have to be in your Bluetooth menu on your phone before you do this. Your phone should then pop up a screen asking for the Bluetooth PIN number. 0000 is the pin.
This should work!
Score 11
16 Comments:
This may work on android too. I don’t have one so I cannot test it
by
This worked for Android as well, thank you so much for this.
by
Attempting to pair with a Samsung Galaxy S4 for my 6 year old. So far ive had no luck whatsoever. The phone will not recognize the device. Not sure what to do. Does anyone have any advice as to how to make this work thats not the same as tips already provided? PLEASE HELP
by
Mikey, thank you for taking time to share this with us. I did as instructed and it paired. however, It isnt controlling anything still. Its an iphone 7. Any additional suggestions? I just purchased this thing today.
by
What's the @ button
by
Show 11 more comments
Add a comment
Just purchased this for my son. Won’t pair to either iPhone 7S+ nor my iPhone XR. So frustrating and disappointing!
Score 4
2 Comments:
Neither is mine. So frustrating!
by
Same here but I broke through .... Finally!!!!
At first the DV Controller is recognized under “My Devices” in the Bluetooth page but has a status of “Not Connected” ... I basically follow the below steps to finally connect:
1- click on the “i” in front of the DV Controller
2- instruct your phone to “Forget This Device”
3- make sure that your controller is turned off
4- before restarting your controller, press and keep holding the bluetooth button “@“
5- ensure your iPhone has the Bluetooth window screen
6- start your controller by pressing the on button (and continuing to press the Bluetooth button)- then almost immediately you will prompted for the code
(0000)
Used it on iPhone 7+ by the way,
Best of luck ,
by
Add a comment
I am trying to pair the controller with my apple iPhone 7 and I’m holding down @ then pressing the on button. It shows the pin and then I put in the code 0000 and it works…. for a second. Then it says connected but switched to not connected. What do I do
Score 3
2 Comments:
I had the same problem
by
That’s the exact same as me!!! HELLLP ffs
by
Add a comment
I've tried all these suggestions to no avail. I keep getting the error saying “Cant pair to divice. Wrong pin entered"
Well !&&*,…it dosent even give me
an area to even type in the 0000 pin all are suggesting.
Junk….dissappointing.
Score 2
2 Comments:
I am also having issues with connecting the tzumi controller to our phones. Keep getting an error message, Incorrect pin. I've never been given an opportunity to enter a pin number
by
Same for me been trying this for weeks and no results
by
Add a comment
Had my controller cabled with USB to my PC. Red light showing on the top of the device. Opened Settings > Bluetooth on my iPhone 6. Pressed and held down the Start button for about 5-10 seconds. The light changed from red to flashing purple and blue. DV Controller appeared on my list of bluetooth devices. Clicked the device name > Clicked Pair. Done.
Score 2
Add a comment
Unfortunately my controller doesn't have a USB port to connect to my pc or phone so this solution will not work.
Score 2
1 Comment:
My controller doesn’t either. And the goggles has an AUX cable but where am I supposed to put that??? I really need help before I smash everything up
by
Add a comment
I got the VR headset and I tried pairing my Nokia 3.1 plus with the controller and it kept saying errors.
Score 2
Add a comment
try this while connecting before it shows error or while showing it pres start continuously that should work if not try the home button as same countinuosly
Score 2
Add a comment
it is a piece of $@$* controller- I have tried to make this pair for at least 2 hours over the course of a couple days - lots of internet searching and nothing works , i am throwin the controller and the goggles in the trash and will at least have the satisfaction of hitting it with a hammer first
I tried it on iPhone 8+ as well as my iPhone11 pro.
I put in new batteries-I held the @ button down while I pressed the power On button, the screen for the pin comes up on my phone i enter 0000 and IMMEDIATELY the blue light on the controller goes off.
Phone asks me if i want to pair and i click Yes and EVERY SINGLE TIME it says pairing unsuccessful.
It is a piece of $@$*
Score 2
1 Comment:
same thing is happening with me. The headset is connecting but not the actual remote. It’s so annoying, I don’t know what to do!
by
Add a comment
It is a bad controller I am trying every way I find on this and on my IPhone 11 it won’t connect no matter what I try to do my advice is to never waste money on this hunk of junk
Score 2
Add a comment
So when I put in the pin0000 and hit pair my controller turns off then I turn it back on and on my iPhone 6s it asks me if I want to pair this device (the controller) I hit pair then I get the notification could not connect to dv controller make shure your device is on and in range so does anyone know how to stop it from turning off or any other solutions
Score 2
1 Comment:
Please good god I’m having the exact same problem if you get a solution to this please let me know.
by
Add a comment
I am having trouble. Using my zte zblade to my tzuml dream vision head set
Score 1
2 Comments:
I am not understanding
by
What you need to do is hold the power button down to the blue light on the controller starts flashing it might take a couple tries but make sure you don't hold it too long it'll power back off it took me a minute to but I figured it out myself
by
Add a comment
I can't get the controller to pair with my galaxy j7 how can I
2 Comments:
For Android I had to hold both start and home on controller and it found the dv controller in like 3 seconds
by
I held the power button down to the blue light on the controller started flashing but if you hold it too long it'll power itself off it takes a couple tries but I finally got it try that it works wonders to
by
Add a comment
When you power it on way to the blue light flashes it might take a couple times but I finally got it sometimes it will shut off so make sure you let go of the button to power it on as soon as it starts flashing
Add a comment
I just got a j7 as well. My plan was to watch streaming shows with the VR. Now to pair them.
First thing you want to do is to open your phone's bluetooth settings page big and scanning. Then on your controller make sure that you have it set to the iOS or the Android phone that you have I have Android so I don't know anything about iOS ones in the button on the right nearest the stick which looks just like a power button on a computer hold that down for 10 seconds it'll start flashing in a little hole and between the two top buttons while you're holding that down it should pop up as a Evo control pad on your smartphones Bluetooth page you want to click the Cog there and then turn it on to switch it to input device on the bottom row of your options or might just say input once that's done it should pair with the Android phone just fine I have one TV controller and one Evo VR controller both connected to my phone's Bluetooth and they work the same. Another fancy option with this as if you can cast your phone to your TV it's a like using a Chromecast and you're a lazy person like me you can use the controller to control your phone on your television screen like a mouse obviously the joystick moves the mouse cursor around the top button and select the bottom button returns your two other buttons that are horizontal or vertical do volume up and volume down and then the other two I think are forward and back holding your phone in your hand while reading a lot of texts can get rather tedious considering I have a 55 inch television to sit in front of me that I can just adjust the font and scroll down Owen to scroll you hold the top button down and move the Joey stick the opposite direction you want to scroll the page hope that's of some help
1 Comment:
Sorry for the typos I actually have the headset on right now and was using the mic to type that in. My apologies if there are any questions or concerns of what I meant by any of those statements just send me a link thanks for understanding
by
Add a comment
I have looked all around it an m
I do not now how to turn it on or connect
1 Comment:
I’m having the exact same problem here and I feel like launching the things at the wall
by
Add a comment
I went to the seller and had him pair mine.
Add a comment
So hit pair on remote but dont have to many things saved and do it like normal
Add a comment
I have the problem too but I found out you have to hold the @ button then push the power button then the code is 0000
Add a comment
I’m having the same problem
Add a comment
It is so raging 😠 I am on my iPhone 12 and I turn off my controller and I hold @ and the power button, I enter the code (0000) I turn my controller on, and it asks me do I want to pair it, I say pair and it says not connected and idk y it is so frustrating😡😡😡😡😡😡
Add a comment
Add your answer
Philis wheatly will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 49
All Time: 30,651
