Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1170 Questions View all
Dropped and display screen is different colors with lines how to fix?
I dropped my iphone 3g and the screen is sometimes white and changes colors and has lines at the right side but i can still hear it open and lock and i am able to take pictures. how to i fix it and if i need to replace the lcd how much would it cost?
Score 20
10 Comments
did you check connector 1 and do a hard reset? press and hold home and power for 10 seconds then release buttons.... you never know it might work and save you quite a lot of money..
by
What if your lock button doesnt work?
by
what if the home button doesn't
work?
by
I have a question
I was on YouTube and my phone start glitching crazy then different color lines pop up on my phone I try to turn it off and cut it back nothing work HELP PLZ ASAP
by
Soooooo my phone fell today and it started to blink and some clear lines appeared on the screen. After I hit my phone w/my hand, it the blinking and the lines disappeared. I turned this off for it to "rest" for an hour. When I turned it on, the problem came back and this time nothing fixed it. Aparte from changing the LCD screen, what can I do to fix it. Pllllzz help!Thanks
by
Show 5 more comments
Add a comment
Chosen Solution
If only your lCD is having issues, you can try replacing that:
iPhone 3G Display
If it is both your LCD and your glass/digitizer that are broken, this is the part you would need:
iPhone 3G Display Assembly
The guides for how to do the repairs are linked on the product pages.
iPhone 3G Display Image
Product
iPhone 3G Display
$29.99
iPhone 3G Display Assembly Image
Product
$59.99
Score 6
Add a comment
Most Helpful Answer
I dropped my phone on the concrete and my screen turned colors with lines in it but I can still read words and go on it the screen is just blue what is wrong with it and how much to fix it
Score 8
1 Comment:
It's an iPhone 4s
by
Add a comment
I dropped my oppo and my screen has gone colourful I need help ASAP please
Score 3
1 Comment:
I was walking and put my phone in my waist went I take it out it is showing me different colors need help what should I do
by
Add a comment
My sister once threw my phone to the ground and apart from all the shattered screen, some colored lines appeared only at the bottom of the phone but it still worked. Then it fell again, and this time, the lines covered the whole screen. So my dad took it to check and they had to change the whole display; so they remove the screen and put a new one.
Score 2
Add a comment
So my phone is glitching and it has lines on one side and the whole screen is green and pink so I can’t tell what color are my apps and I don’t know how to fix it. HELP
Score 1
Add a comment
I dropped my moms Xperia xa2 Sony phone on my rock and concrete driveway and now the screen is showing colored stripes even tho I still hear the login sound when I login using my fingerprint I want a way to fix it w/o removing the screen
Add a comment
Add your answer
soccerplayer32489384 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 104,021
