Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
874 Questions View all
People can’t hear me on calls, or FaceTime etc
Hi,
Have got a iPhone 8 , people can’t hear me on any phone calls, FaceTime, etc . Have tried using voice memos to record and doesn’t pick up any sound.
When I record a video with the back main camera it does record sound. And sound plays ok .
Is this a speaker issue? And which one would need changing?
Thanks
Score 1
3 Comments
Have you tried using the speaker phone mode on calls?
by
Yes still don’t get any joy though.
by
When i call on discord or facetime or instagram my friend cant hear me but i can still hear them. I reset my phone i deleted the apps and downloaded them back and im still having this problem
by
Add a comment
Chosen Solution
This sounds most likely like a bottom microphone problem. As was already noted, I would try and make certain there’s no debris stuck in the bottom grills. Although it was mentioned to use compressed air, I would recommend using something like Blu tack, or even tape to pull stuff out since that’s generally more effective than trying to blow it inward.
If it looks clear, it may be the microphone itself is not working properly in which case you’d be looking at replacing the lightning dock assembly.
iPhone 8 Lightning Connector Assembly
iPhone 8 Lightning Connector Assembly Image
Product
$24.99
Score 3
Add a comment
Hello,
2 questions:
  • Are you using headphones? And if you are have you tried switching them out?
  • Have you tried blowing out (GENTLY) the speakers with some air?
To remove the dirt in the microphone:
  1. Open some compressed air
  2. Blow it at the grill on the top
  3. Blow into the bottom left microphone
  4. Blow into the mic at back on the right of the camera
  5. Most of the dirt should be gone so people should hear you
Another possibility is in your microphone privacy settings:
  • To turn on your iPhone’s microphone, go to Settings > Privacy > Microphone > make sure the app you’re using for calls if toggled on.
Another possibility (very rarely) is your network settings try this to reset your network settings:
  1. From the home screen, tap Settings
  2. Scroll down to, then tap General
  3. Scroll down to, then tap Reset
  4. Tap Reset Network Settings
  5. Tap Reset Network Settings to confirm
You can also try to force reboot your iPhone and that may help your situation:
How to force iPhone 8 to reboot
Lastly you may need to replace your speaker if all else fails:
iPhone 8 Troubleshooting
iPhone 8 Earpiece Speaker Replacement
Good luck!
iPhone 8 Image
Guide
Difficulty:
Very easy
20 seconds
iPhone 8 Earpiece Speaker Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Score 1
Add a comment
Add your answer
dan morrill will be eternally grateful.
Past 24 Hours: 15
Past 7 Days: 108
Past 30 Days: 614
All Time: 23,253
