Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
167 Questions View all
Charging/ Lightning port on working
My charging port will not work to charge my phone. Headphones do not work with Lightning port either. Right now must charge phone wirelessly only. Can't find lightning port replacement part or instructions
Score 1
Add a comment
Most Helpful Answer
if your in the us try mobilesentrix, uk/europe try headlane.co.uk
Score 3
Add a comment
Hi
See this as something else to try In the meantime while you are seeing about getting your port fixed through the link that @tech_ni thanks fully provided:-)
Get a torch/flashlight and shine it into the port to check for dust and debris
If there is any get a sewing needle or some tweezers and carefully remove the dust and debris in the port(it can be surprising how much can fit in there!)
If that doesn’t work, turn your iPhone off and try a very small amount of isopropyl alcohol on a clean toothbrush and scrub away gently and the port to remove any corrosion that may stop it from charging,leave it to dry for a 30mins-hour just to be safe(just don’t get any on the lip between the screen and the chassis incase it gets in!
Hopefully this helps
Any questions please ask
Score 2
Add a comment
Add your answer
aaronroesler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 270
