Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
167 Questions View all
URGENT, DEAD SCREEN/BROKEN SCREEN, how can I test if it still charges
for iphone 12 (normal)
the screen is broken
the screen does not power on
the charging port was ever so slightly loose when i opened the phone
i tightened it and now its sturdy
Everythibg else seems ok
But
I didnt get any response (vibration) when touching or power button (screen was not attached)
No response from charging, wirless or normal port charging
So
Is this because theres no screen and thus will change when i replace screen?
Or could it be a problem with another part?
Help me how you can, thx ifixit family
Score 2
6 Comments
Also can i just test it with another iphone screen? Or zill it less sonthing up?
by
get a usb amp meter and it will tell you if its taking power
by
Not helpfull, i dont care if ut take power, i care that it not vibrating when buttons are pressed l, i need ti kniw if this is becuase if lack of screen ir naw
by
Nate Dog, you asked how you can test if it still charges then when Daniel suggests an amp meter you say you don't care if it takes power. You need to decide if you want help or not as when it's given you reject it. Just plug it into a computer and see if iTunes recognises it.
by
Bro, im asking if i need the have the screen in to see if the buttons vibrate/fucntion
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
It depends on the the settings for the phone. Haptic feedback may be off. But you do not need to have the display functional, or even connected for the phone to boot, or charge. You could definitely test with another iPhone 12 or 12 Pro Display. Try toggling the ringer switch to see if that prompts any vibration.
Plug into iTunes to see if it is detected. It may also make noises or vibrate when connected to a charger. But honestly, there’s no sure fire way to know if it’s powered on or charging without some some of multimeter or a DC power supply. You can hazard a good guess, but if the phone is set to not vibrate or make noises, then my usual methods may not be helpful.
Score 2
Add a comment
Add your answer
Nate dog will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 81
All Time: 939
