Apple's mainstream 2021 iPhone was released on September 24th and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 12.
99 Questions View all
My phone is stuck on 1 percent
my phone is stuck on 1% its kept turnin gon and off every 3 minutes but when i took it out off the charger it stopped turning on and off amd shut down completely as am writing this i put it on the charger and it opened and i got so exited 20seconds later it shut off all my hope was gone off it turning on again its a new phone too buti think i know what the reason is it got cracked idk where (it used to be my dads phone) he went to fix it at this store it cost 1500sr which is alot and i think that the people who supposdely fixed the phone put a bad part in it and i think that part is the battery and the screen because when i go into the settings it tells me "this is unknown part etc"and by unknown part its talking about the battery and the screen now i cant solve hw or log into social media acounts because everything is connected to my phone so if i try to log in to an acount it sounds a notifaction to my phone which is broken
Score 2
Add a comment
1 Answer
Most Helpful Answer
They may not have connected the battery properly, not reinstalled the shield over the battery connector, or damaged a part of the battery gas gauge circuit.
I know on some of the older models like the 8, x, xs, xs max, xr, and more, it's possible to knock off a filter near the battery connector for the batter gas gauge circuit. There's a bms board attached to the battery that will relay information back to the device such as cycle count, voltage, temperature, and more. Typically when gas gauge isn't communicating with the device it will lead to the issue you've described where the device will only read 1% and reboot every few minutes.
Score 4
Add a comment
Add your answer
Kinda Khalid will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 233
All Time: 1,034
