Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1207 Questions View all
Panic CPU x caller - rebooting every few seconds
I need some help. My iPhone restarts every few seconds when I unlock it. When it is locked it works all the time without rebooting.
I read the error code but I don't know what it means, can someone guide me where is the problem?
Panic code
{"bug_type":"210","timestamp":"2023-06-28 03:14:09.00 -0700","os_version":"iPhone OS 16.5 (20F66)","roots_installed":0,"incident_id":"D6DCF4B5-6A5E-446E-B318-FC8AB236FECB"}
  "build" : "iPhone OS 16.5 (20F66)",
  "product" : "iPhone10,3",
  "socId" : "8015",
  "socRevision" : "11",
  "incident" : "D6DCF4B5-6A5E-446E-B318-FC8AB236FECB",
  "crashReporterKey" : "c27374456cd62022bf606fff6bdb02803499bb8a",
  "kernel" : "Darwin Kernel Version 22.5.0: Mon Apr 24 21:10:12 PDT 2023; root:xnu-8796.122.4~1\/RELEASE_ARM64_T8015",
  "date" : "2023-06-28 03:14:09.29 -0700",
  "panicString" : "panic(cpu 2 caller 0xfffffff0105e0f54): AOP PANIC - No pulse on 0x109b248 - main(4) - \nuser handlers:\ntraceBuffer : \n280000008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140\nNo pulse on
Score 3
Add a comment
Most Helpful Answer
We might need more of the panic, but in my recollection an “AOP No Pulse” panic often refers to the Taptic Engine (Vibration motor). That could also point to issues with the charge port since the Taptic Engine connects directly to the dock flex cable rather than the logic board. If you can upload a bit more of the panic it might help, there are sometimes some extra clues further in the text.
Score 1
2 Comments:
I added a link to the whole panic
but the vibration works normally after toggling the mute button on the side.
by
Hi,
I am having the same issue on Iphone X with the same error code. Have you been able to fix it ?
by
Add a comment
Hi,
Add a comment
I do not remember exactly. but it was something with the ambient light sensor on the upper flex. Replacing the sensor flex with flood iluminator and proximity sensor fixed the error, but faceid needs to be programmed and repaired. In my case, the error occurred after flooding the phone.
Add a comment
Add your answer
kamillski will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 171
All Time: 1,137
