Announced on October 13 and released October 23, Apple's flagship smartphone for 2020 features a 6.1" OLED display, a triple-lens rear camera system with LiDAR, and 5G. Successor to the iPhone 11 Pro.
93 Questions View all
External Speaker not working - all sound coming through earpiece
I ordered a new external speaker because of the issue where all sound is coming from the Earpiece speaker. Replaced the external speaker and no change. What am I missing? Any troubleshooting tips? What have I missed?
Add a comment
Most Helpful Answer
Did you yourself replace the speaker? If so, is it possible you damaged the flex cable? You should try spraying isopropyl alcohol on the contacts.
Score 1
2 Comments:
Yes replaced it myself - What flex cable are you referring to? The external Speaker at the bottom is a self contained module with 4 screws with no cable. Contacts were clean as a whistle so I didn't think about cleaning them. I guess I could try it again and clean the contacts and see. Couldn't hurt. Any other suggestions?
by
@ppeter01 No other suggestions. Try cleaning the contacts and get back to me
by
Add a comment
Hi Paul,
I'm going on the assumption you tried all the possible software fixes before you resorted to replacing the speaker, a full DFU mode restore, for example.
So, given that, you definitely did the right first step in replacing the speaker. If we look at all the things that can go wrong, we've got the speaker which you've verified already, then the electrical signal path to the motherboard which is realistically the only other thing you could fix yourself. That would mean replacing the lightning port assembly that connects the speaker to the logic board. iFixit doesn't have a guide for that, but there's a Spanish site called Nadie Me Llama Gallina, or Nobody Calls Me Chicken that has exactly what you need.
Manuales / Apple iPhone 12 Pro / Load flex
If it was my phone, that would be my next attempt at fixing the problem. Unfortunately, if that doesn't do it, you may well be looking at board level repairs that would take expert level microsoldering skills to fix. So I'd say give the lighting flex a try and let us know what happens.
Add a comment
This is a ringer issues just replace it with cleaning metalic grill.Simple method i follow this to fix.
Add a comment
Add your answer
Paul Petersen will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 82
All Time: 243
