Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
400 Questions View all
Tengo problemas con panic full
{"bug_type":"210","timestamp":"2023-10-09 00:30:57.00 -0300","os_version":"iPhone OS 16.5 (20F66)","roots_installed":0,"incident_id":"E1359F80-E32C-4AD5-B086-5F8B073B35E0"}
"build" : "iPhone OS 16.5 (20F66)",
"product" : "iPhone11,2",
"socId" : "8020",
"socRevision" : "11",
"incident" : "E1359F80-E32C-4AD5-B086-5F8B073B35E0",
"crashReporterKey" : "f2aa523d642a578ea63139d414196d9bb46960f9",
"kernel" : "Darwin Kernel Version 22.5.0: Mon Apr 24 21:10:51 PDT 2023; root:xnu-8796.122.4~1\/RELEASE_ARM64_T8020",
"date" : "2023-10-09 00:30:57.74 -0300",
"panicString" : "panic(cpu 0 caller 0xfffffff01441c598): userspace watchdog timeout: no successful checkins from thermalmonitord in 180 seconds\nservice returned not alive with context : is_alive_func returned unhealthy : current 7fffffffffffe, mask 37ffffffffdff, expected 37ffffffffdff. SD: 0 BC: 1 RC: 0 BS: 2, Missing sensor(s): TG0B \nservice: backboardd, total successful checkins in 1073 seconds: 106, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 1032 seconds: 104, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins in 1073 seconds: 105, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 1073 seconds: 106, last successful checkin: 0 seconds ago\nservice: thermalmonitord, total successful checkins in 1073 seconds: 73, last successful checkin: 180 seconds ago\nservice: runningboardd, total successful checkins in 1073 seconds: 106, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins in 1073 seconds: 105, last successful checkin: 0 seconds ago\nservice: con\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 20F66\nKernel version: Darwin Kernel Version 22.5.0: Mon Apr 24 21:10:51 PDT 2023; root:xnu-8796.122.4~1\/RELEASE_ARM64_T8020\nFileset Kernelcache UUID: 1AF7443734C73F52E3C5898E71DF2AA1\nKernel UUID: 9ED7ED28-9213-39A2-8130-0B56D42D04EA\nBoot session UUID: E1359F80-E32C-4AD5-B086-5F8B073B35E0\niBoot version: iBoot-8422.120.66\nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\n
Add a comment
1 Answer
Most Helpful Answer
Hi David,
I took the liberty of trimming the size of your panic log, as we really only need the first page of it to find the problem. In your case the magic clue is right here.
If you check @flannelist's excellent Wiki article on kernel panics, you'll find that the TG0B sensor is a battery sensor, probably for temperature. Essentially, the little circuit board mounted on the battery that's called the BMS or Battery Management System has failed. In order to replace it, you'll need to replace the battery since all batteries come with the BMS already installed.
So the short story is, replace the battery and you should be fine.
Score 3
Add a comment
Add your answer
DAVID Cardozo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 56
