Model No. A1367 / 8, 16, 32, or 64 GB capacity
896 Questions View all
iPod not charging / charging port problem
Having truble with the charging port. at first i would move it around and it would charge but now it stop. i looked around to see if i find any videos on this but haven't found any. Please Help!
Score -1
Add a comment
1 Answer
Chosen Solution
tioiggy, here is my answer from a similar question "You will of course have to totally disassemble the iPod. The dock connector is solder onto the board. You will have to do lots of soldering. You will have to un-solder two anchors and about 30 connections, they are very small and close to each other. So you have to take extra care not to shorten the pins out. After that you will have to resolder all those connections and the two anchors. Not an easy task, unless you are used to soldering small pieces. This video will give you an idea what you are up against. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
tioiggy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,524
