The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
22 Questions View all
Motion recording cancelled due to writing speed of card
Since not long ago, I face a problem with the recording. I record videos that contain or not action scenes and the recording stops (e.g. after 20 sec.) with the message « Motion recording was cancelled due to the limitation of writing speed of the card ». I don't understand why it worked in the past and that the problem started many videos after starting using a very good card (SanDisk Extreme HD Video, 30 Mb/s; 16 Gb). Can this problem be fix?
Thanks,
2 Comments:
Have you tried a different card? I am a bit confused. This error started when you started using the SanDisk or it happened before with another card as well?
by
Hi Eric, I have the exact same problem! LUMIX G7 4K, I have been using it with an 8gig 4speed Kingston card absolutely fine, But I need more space to film in 4k so I got a SanDisk 32g class 10 and it keeps canceling recordibg due to speed of card.
If you found a fix please post for me. Thanks mate.
J
by
Add a comment
Eric, it is possible that your camera is having with the Speed Class 10. You may need a firmware update. I would suggest you try either a class 3 or a class 6 card and see if that will work. Here is a bit more information I found about your card "The limitation of this card is that it normally operates at 20MB/s and only achieves 30MB/s in the few devices that support UHS-I. If your device doesn't specifically state "UHS-I", try a more "normal" version. This is based on research and responses from SanDisk. Hope this helps, good luck.
Add a comment
If you switch your video recording mode off of 4k to regular HD it works smoothly... with no cancellation.
Add a comment
You just need a faster sd card because lumix cameras film at 100mbs
1 Comment:
If you switch from 4k 30p to 4k 24p in your Rec quality setting that should fix the issue.
by
Add a comment
This happened to me as well with a card that I know is fast enough for the G7. I had used it in the past and everything had been fine but one day I ran into this problem and have been looking for a solution. I am going to try to format my SD card in ExFat to see if that will fix my problem.
1 Comment:
It's probably worth mentioning that I have another SD card that doesn't have this issue
by
Add a comment
i have this message come up after formatting my SD card now i don’t know what to do as it worked fine before. Is there a possible way to format the SD card back?
1 Comment:
I would just buy a new memory card with a higher recording speed. I had a 60MB memory card and I switched to a 90MB and it doesn't show up anymore. Tell me if it works!
by
Add a comment
Add your answer
Eric will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 59
All Time: 10,393
