Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 Questions View all
Heat blows from dash vents only not floor or defroster
I have a 2007 Dodge Grand Caravan. The dash vents are the only vents that work. It blows hot air so I don't think there is anything wrong with they heating system. There is just no air from floor vents or defroster. Years ago this was controlled by vaccum lines, but now everything is electronic. Any ideas?
Score 3
3 Comments
Needs computer recalibrated
by
I have a 2010 Honda CRV with the same problem and I’m having a hard time finding a solution would disconnecting the battery also work to reset the computer to make it work the right way again .
by
you more than likely need to change the blend door motor for the defrost and feet. it will require the dash to be removed to get to these
by
Add a comment
Most Helpful Answer
We have a 2005 Chrysler TC with the same problem. I have found that resetting the console computer by disconnecting the battery cable, waiting, and then reconnecting it will often "fix" computer-related problems. Also corrected by this method was a door lock problem--lights would flash using remote key fob, but no lock action.
Score 2
Add a comment
I also have a 2007 Dodge Grand Caravan and ony the air centre vents were working. I tried disconnecting the negative lead for 10 minutes, and while it was disconnected I cleaned the lead so there would be a good connection. I reconnected the lead and everything was working again. I love going to the internet for my automobile solutions it has saved me lots of time and money.
Score 2
1 Comment:
yes, but my question is all vents work except the floor vent, so what do i do by the way it;s a 2012 dodge caraven
by
Add a comment
In my experience, there is an actuator that mounts on the blower motor housing that had became stuck, or otherwise failing to switch the curved blower stator that directed the flow of air from the blower motor. Mine had failed bc of moisture from a leaking windshield/air cowl seal and had ultimately damaged the blower motor and actuator. I'm sorry if my description is lacking, but it's basically just a small rc car motor that engages when u select different fan outputs on the dash air controls. Hope it helps!
Add a comment
Add your answer
Kerry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 12,475
