The second generation of the Mazda 3, also known as the Mazda3 and Mazda Axela, sedan and hatchback series by Mazda.
11 Questions View all
D/S window is not working!
I have a (2010) Mazda 3 sedan & my Driver Side window suddenly doesn't work , but the other 3 window works fine. I'm curious if it could be the motor or switch? How do you remove the switch panel as well? Thanks everyone!
Score 1
Add a comment
Most Helpful Answer
Hi Johnny,
It could be the switch/regulator. I would start from there. Then I would check the motor of the window.
Here are the instructions on how to remove the panel. A guide with images (although for a 2004 model) you find here.
I am not sure if this would fit your model/make and if at all necessary, but check this out.
Steffen
Score 1
Add a comment
Hey, I attached the interior trim workshop manual from Mazda for this specific vehicle
2010_Mazda_3_Interior_Trim_WORKSHOP_MANU.pdf
Serge
Add a comment
Add your answer
Johnny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 6,805
