Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
My iPhone keeps rebooting itself
I think this should be a hardware problem but I don't know which part of the phone got wrong, my phone can hardly be restored ( succeed once only) and it keeps on restarting itself. my phone was not jailbroken. Rarely my phone can enter the normal iphone welcome screen but it restart itself after sometime. I said it might be a hardware problem is because I tried to take the battery out and then connected the phone to the computer, but it still reboots itself
Score 5
3 Comments
Please can anybody help me with this. Thank you
by
I've uploaded a video of whats happening to my phone, the same thing happens even if I managed to restore it
http://www.youtube.com/watch?v=klh3HMWAM...
by
It sounds like a boot logo loop. You may try this. Hold power and home button until the screen goes black, then the apple logo turns on. as soon as the logos shows up, keep your finger pressed hard against the power button, let go of the home button, and hold down the turn up volume button(as well as power button). hold these until you get to your lock screen. this should fix it
by
Add a comment
Most Helpful Answer
Sounds as though the battery is dead. Does it do this when you have it plugged into the charger?
Score 3
8 Comments:
yes, I just added some extra info in the post
by
Try a new battery.
by
do you know its there any other possible hardware fault either then battery? thank you
by
Lawrence, start with what Scott Dingle suggested. Remember that your computers USB port only supplies a max of 500mA which may not be enough.
by
just received a new battery replacement and installed, but it still reboots itself (only shows the apple logo), I notice one thing is that the phone can boot into the normal welcome screen once the low battery screen appears and needed to plug into the computer, but otherwise it can rarely boot into the welcome screen.
by
Show 3 more comments
Add a comment
Nope It's not the battery. I have this problem too, and the first time it was the battery. I took out the battery and replaced with a working battery from an iPhone 4s. My iphone was fixed with the battery problem. Then as soon as I installed the battery, the phone turned on and after the apple logo the screen shows a dark screen then like after 30-secs it restarts it self then does the same thing over and over again. I tried hard resetting it but it was no use.
I need a solution as soon as possible!!!
Score 1
Add a comment
Just had the issue with my 4S,
Sounds odd, but goto Settings-> Cellular Data and turn it off and then wait 30 seconds and turn it back on.
Then go to Settings -> General -> Reset and then Reset all Settings.
This should stop the Booting issue.
One other issue may be an APP that is not quite right. Try deleting some of your previously downloaded APP>
Hope this helps you, it solved my issue.
BOB
Score 1
1 Comment:
BOB: Many thanks for this - after a week of constant and worsening rebooting my phone was next to useless and I was at the point of giving up and just buying a new phone, but tried this and hey presto - phone working fine again! Just saved me a £440 / $700 purchase for another few months.... Many Thanks ! Dave
by
Add a comment
Battery terminal lost contact or you ripped a small component behind the terminal.
First case: resolder those joints (careful special equipment needed)
Score 1
Add a comment
Phone is not charging and it's self restart and showing I simbal autamicly
Add a comment
My 4s keeps restarting every time i turn it on and keeps crashing when I'm on apps, sometimes it doesn't turn on at all, the problem started ever since I accidentally got it whacked out of my hand thankfully it didn't crack, I also did a software update and the battery seems to drain so fast and it charges extremely slow, what do I do??
Add a comment
press and hold the home button, insert the usb while connected to the pc, not a power outlet. this puts it into dfu recovery mode. restore the device
Add a comment
Add your answer
Lawrence will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 21,482
