The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
73 Questions View all
Pins or SIM card contacts are broken on blackberry Z10
SIM card is not recognized and it looks that 1 or 2 pins on the SIM card tray are damaged or broken . Can this be repaired or replaced or all motherboard has to be changed . And where an you buy spare parts for Z10
Thanks
Score 7
1 Comment
This should be a relative new phone. If you are covered under warranty, I would try that first.
by
Add a comment
Chosen Solution
Hi Nabil,
Can you figure out if the pins are just damaged or if they are actually broken?
In case the pins are damaged, there might be a chance to simply but carefully bend them back into their original position, for example with a tiny item or tool (e.g. toothpick or mini screw driver). Make sure that you remove the battery first before you try any repair on the sim card reader.
Use this teardown of the Z10 here on iFixit which will help you how to open your phone.
Steffen
Score 3
Add a comment
Here is some information on the repair
http://www.mobiledeviceworkshop.co.uk/bl...
Add a comment
Add your answer
Nabil Hamdan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 18,715
