Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 11,328
1 Comment
Thanks oldturkey03! I will check this out immediately.
by Berry
