Repair and disassembly guides for Sony DVD players.
65 Questions View all
DVD player is not reading DVDs or CDs
Sony DAV-DZ690K
I own this four years old Sony Home Theatre system. I noticed recently, it is not reading either DVDs or CDs. When I insert a DVD, it takes a while to read, but shows 'No disc'. The tray simply opens on its own.
I appreciate your help to solve this problem.
Thank you so much in advance.
Narni
Score 5
2 Comments
Mine takes awhile loading then says can not play this disc.
by
I wanted to know the spray that is used in cleaning of the lens inside the DVD
by
Add a comment
Most Helpful Answer
Narni, sounds like either a dirty laser or a burned out laser. Try one of the commercially available lens cleaners. If that does not work you may have to disassemble your player and clean/replace the lens assembly. Hope this helps, good luck.
Score 2
2 Comments:
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs.
Any advise is welcome!
by
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs. Any advise is welcome!
by
Add a comment
Try another disc or try another drive to make sure which causes the problem. In most cases, it’s a scratched DVD or a dirty drive. This post has shown all the possible reasons and fixes.
Add a comment
Push power protector
1 Comment:
Push
Reasonpower protector not working
by
Add a comment
Add your answer
Narni will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 13,649
