Why wont my engine fire or run?
It will turn over. but it will try to start up on starting fluid. tjen it quits trying to run just turns over. whats wrong??
I would suspect fuel delivery system and the high voltage circuitry.
It has all kinds of fuel pressure. and yhe high voltage circuitry? how might i check that?
Search this site: bobistheoilguy.com Look in the Automotive and Mechanical forums.
You will also need basic voltmeter and ohmmeter test equipment.
i have almost the same problem my dodge neon wont even turn over it doesnt even do a click what do i do ? can anhy body help me
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 314
similar problem on our car turned out to be a loose fuel pump connector..
by pollytintop
