Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
56 Questions View all
Buy the Sata mini cable
Lost the SATA cable's super-thin profile allows the hard drive to be plugged in, as well as allowing it to be clamped securely into the enclosure via the rubber cover (and metal clamp).
Where do I find that cable?
I fixit doesn't have it for sale?
Please help me!!
Yours truly
Armando Areias
Score 8
3 Comments
Hello,
For my part, I am looking for the SATA cable's super-thin for my AirPort Time Capsule because by changing the hard drive I damaged the pin of the connector on the cable.
Where can I find a new cable?
https://d3nevzfk7ii3be.cloudfront.net/ig...
Google has not been able to give me concrete answers.
Best regards,
by
@aareias & @lemur1en - Here's the part you're looking for: Hard Drive Flex Cable
by
authorized Apple Repair Technician can order one for you. So any non-Apple store repair center (maybe even BestBuy or Microcenter). But it will cost a lot...
by
Add a comment
Chosen Solution
Google is your best bet…
If this answer is acceptable please remember to return and mark it.
Score 2
1 Comment:
So far no luck with google or Ebay. I have to go to Apple Support...
by
Add a comment
Most Helpful Answer
@floceen - Here's the best place to get replacement parts for the A1470 Time Capsule and AirPort Extreme units: BeetsTech- A1470 Time Capsule
Score 3
2 Comments:
@danj do you know what ever happened to @originalmachead? I never met him...
by
@pccheese - Sorry no, people drift in & out.
by
Add a comment
Are you actually trying to modify an AirPort Extreme to hold a hard drive? It sounds like it. You lost the sata ribbon and rubber plate and metal plate for a 2013 Time Capsule? Sounds a little strange. How do you lose all that?
Can't help you with those parts I'm sorry but if you are looking to get them to try the Extreme mod then think twice as the logic board does not even have a point to plug the sata ribbon/cable into.
Just thought I would mention that. Apologies if I am misreading your post.
Score 1
5 Comments:
@opinio: Post is pretty clear, your answer does not contain any information pertaining the ways of finding solution. Kindly refrain from unnecessary inaccurate comments (main board SATA connector is J0900, pinout is known)
by
Thanks. I didn't find a place to buy the SATA connector, but thanks anyway.
by
Do you think this would work? from the Mac Mini http://www.amazon.co.uk/Festplatten-Flex...
by
"Do you think this would work? from the Mac Mini"
No definitely not. The TC and mini connectors to the logic boards are completely different. Both are proprietary. The TC connector is long and rectangular, while the mini is far shorter and almost square. Plus the mini sata ribbon is L shaped and larger and the TC is almost straight and short.
by
no, it's for different connector, the one in TC is different.
PS To close the topic, mainboards only appear the same in TC. On the opposite side its missing number of microchips.
It is not possible to attach HDD via sata connection without replacing mainboard.
by
Add a comment
Hello Everybody,
I have just had the same problem :-( and I would like to know:
1) If it is possible -safely enough- to unplug the SATA connector from the mainboard side; some say no, but further expert advice is always welcome;
2) If it is still possible to find and buy a working sata cable for the Time Capsule A1470, don’t mind if it’s second hand.
Thank You Everybody
(and thank you Apple for making your products so easy….to repair, I was just succeeding in replacing the broken fan, when the HDD went the wrong way when I tried to reinserting it)
Score 1
Add a comment
Very sad… I have the same problem: damaged the cable after cleaning the ventilator. (Cleaning worked well, no more heating problem and noise).
it seems those cables are not available anywhere… costly mistake. External usb harddrive will have to do :(
Score 1
2 Comments:
Yes, it seems impossible to find one without buying a whole Time Capsule :-(.
An external USB drive isn't either elegant or 'invisible', but it looks like the only viable solution. I bought a solid external case and put the original TC HD into it. It's more than a year now, it's still working.
by
Same situation. looked everywhere for quite sometime. External case (good tip) or complete external harddisk is all that is left to do I guess...
by
Add a comment
While I have broken the sata connector of my Airport Time Capsule in changing the HDD, is it possible to buy a new mother board and to whom ?
Thanks for your answer?
1 Comment:
Maybe you could buy one a "broken" one off eBay? Maybe you can get a cheap a time capsule that doesn't do wi-if anymore or that has a bad HD. Since you only need it for parts.
by
Add a comment
Add your answer
Armando Areias will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 4,809
