Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
784 Questions View all
Can I Upgrade Airport card to get Bluetooth 4.0 and BLE?
Just wondering if I bought a airport card for a 2012 macbook pro and swapped into my early 2011 13" macbook pro, would it then work with Bluetooth 4.0 and BLE?
Cheers
Score 19
11 Comments
Please help me
can you confirm that bluetooth 4.0 module is the BCM94331PCIEBT4AX ?????
Thank you very much
by
no it is not, BCM94331PCIEBT4AX is the Bluetooth 2.1 + EDR
BCM94331PCIEBT4CAX is the Bluetooth 4.0
that C needs to be there!!! DONT FORGET THE C
CCCCCCCC
AHHHHHHH!!!!!
"yer welcome"
by
BCM94331PCIEBT4CAX Bluetooth 4.0
http://www.aliexpress.com/store/product/...
by
This guy is selling BCM94331PCIEBT4CAX Bluetooth 4.0
http://www.ebay.co.uk/itm/BCM94331PCIEBT...
by
how should the BCM94331PCIEBT4CAX be reported in the OS X System Report?
I see
Manufacturer: Broadcom
Chipset: 20702A3
Firmware Version: v151 c5844
Is that correct?
by
Show 6 more comments
Add a comment
Chosen Solution
Your current built-in Bluetooth is 2.1+EDR to get to Bluetooth 4.0 the easiest way is to use an external USB adapter. Or, follow this FIXIT guide MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement
The Mid-2012 model has the AirPort/Bluetooth board that supports Bluetooth 4.0. If I remember correctly is a Broadcom BCM94331PCIEBT4CAX
Which MacBook Pros can support Handoff/Continuity?
Score 5
2 Comments:
Dan: as a lot of sellers sell the entire Wi-Fi card unit together (bracket, card with tape over it, and flex cable), it is impossible to discern which model the WiFi card is, so most sellers will mention the flex cable ID.
There are two versions 821-1311 and 831-1312. While these cables are identical in function, I believe the former cable is included only in the 2011 laptops, which we can deduce that the BT 2.1 card is also included with such a cable.
Therefore BCM94331PCIEBT4CAX should essentially equal 831-1312 for ordering and identification purposes...can you confirm this theory?
by
The number is not what you think. Each supplier Apple used has different supplier numbers.
by
Add a comment
Most Helpful Answer
Just to correct this thread for the help of others, you need the CAX card:
The Bluetooth 4.0 part is BCM94331PCIEBT4CAX.
The Bluetooth 2.1 + EDR part is BCM94331PCIEBT4AX.
Score 14
Add a comment
They are compatible, just replace the cards
Score 3
6 Comments:
so adding this means that when upgraded to yositime the 2011 will support handoff?
by
At this time point the answer is No. Apple has linked Yosemite directly to the system ID string so these features are limited to certain models not the given Bluetooth hardware it could have been upgraded or added (this could change). Review the following Bluetooth LE Adapters Don't Enable OS X Yosemite's 'Handoff' on Older Macs.
by
As far as I can see, it's obvious that Apple has dropped support for Handoff with 2011 MBP's, at least with the beta so far. I would imagine this will remain the same, as Handoff never really "officially" worked for my MBP (early 2011) even with the first beta, regardless of the option which showed in the "General" pref pane at the time.
It's kind of irritating for those of you who do not do some research before asking questions... but in order for Handoff to work for a machine that it does not natively work for, you need to upgrade your wireless card to the 2012 . If your system does not support the new wireless card (in other words, doesn't have all or the right cables attached to the motherboard), Handoff will not work for you, regardless of what you do. Simply adding a bluetooth dongle will not work either, unfortunately...
by
So, for those who have early 2011 MBP's and who are willing to upgrade the wireless card, you may have luck with keeping this enabled, so long as you follow the instructions that the user @iammatthius included on page 4 on this thread:
http://forums.macrumors.com/showthread.p...
http://d-h.st/2eZ
by
1) open Terminal type sudo nvram boot-args="kext-dev-mode=1"
2) reboot your MBP
3) your wifi will not be working at this moment, replace the file IO80211Family.kext in Go>Computer>System>Library>Extensions
4) open Terminal type as below:-
sudo chown -R root:wheel /System/Library/Extensions/IO80211Family.kext
sudo chmod -R 644 /System/Library/Extensions/IO80211Family.kext
sudo kextcache -system-prelinked-kernel
sudo kextcache -system-caches
5) now reboot your MBP again.
6) now you will see System Preferences>General> will have handoff enable option
7) open Terminal type kextstat | grep AirPort
by
Show 1 more comment
Add a comment
I just upgraded to Yosemite Beta 4 (14A379b), reapplied the fixes, and everything is happy again!
4 Comments:
Beta 4???? Now GM released.
by
Public Beta = Beta 4 (14A379b)...
Developer = Golden Master Candidate 1 (14A379a)
by
Just upgraded from Yosemite Beta 4 (14A379b) to Beta 5 (14A386b) and did *not* need to reapply the fixes. Everything still functional.
by
Just upgraded from Yosemite Beta 5 (14A386b) to Beta 6 (14A388b) and did *not* need to reapply the fixes. Everything still functional.
by
Add a comment
great thanks! i also have a macbook pro 17-inch mid 2010 the board is bit def and only has three antenna plugs on it is this a problem or could i maybe replace the antenna to match the new board too
1 Comment:
So far only the dual function (combo) AirPort boards have been tried. The 17" MBP uses discreet bluetooth & WiFi boards and they are not near each other. At present there is no options for your system.
by
Add a comment
Add your answer
Nenad Tarlac will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 44
All Time: 64,701
