Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Can I replace an iPhone 5s screen with a iPhone 5 screen?
I have cracked my iPhone 5s screen. An iPhone 5 screen is a lot cheaper than a 5s screen. I know the home buttons are different, but I could care less about having touch-ID. So is it possible that I could put an iPhone 5 screen on a 5s?
Score 42
8 Comments
Thanks for useful informations.
by
thank you, the two phone look like each other in outside but are différente inside
by
can you do iphone 5c
by
Can i use 5s display on iphone 5...?
by
can i fixed iphone 5 board on 5s
by
Show 3 more comments
Add a comment
Chosen Solution
Unfortunately, you can't. They have different ribbon cable layouts.
Score 31
5 Comments:
can i put a iphone 5c screen on a iphone 5s ???
by
no you can't
by
I'm use 5s LCD on iPhone 5
by
can i put 5s disply on 5 motherboard
by
can i put a iphone 5 screen on a iphone 5s ???
by
Add a comment
Most Helpful Answer
Alex is correct. I fix iPhones professionally, and iPhone 5s screens cost 2-3 times more than iPhone 5 screens, at least the high quality ones. The ribbons and brackets are different.
If this was helpful at all, 'accept' my answer, or click the up arrow. :)
Score 43
5 Comments:
What about the digitizer
by
My iPhone 5s screen cracked . its a white iPhone with a white screen . can i replace the screen with a black iPhone 5s screen?
by
Yeah joe Ive done that the color has no effect on the actual product :)
by
What the main button on the 5S stay on the phone while changing the screen and if so when you put the 5 screen onto the 5S is would that be compatible what the 5S than still work with the 5 screen on it leaving the button with the 5S on it
by
Adakah sya boleh menggunakan skrin iphone 5c pada iphone 5s ?
by
Add a comment
No you can't, 5/5c/5s screens are not interchangeable.
Score 12
2 Comments:
how about the batteries
by
And how about the cameras
by
Add a comment
No, their flex ribbons are different.
Score 4
Add a comment
Sadly no, one of the major different parts to the 5s and 5 screen is the home button layout one is more spaced out than the other when you place the home button plate over it . It overlaps and there isn't enough space for the ribbon cable and the little plate. NO NO NO NO NO
Score 3
1 Comment:
by
Add a comment
Unfortunately NO,
The flex cable are different, so you cannot do that.
Sorry :)
Score 3
Add a comment
%#*@ thanks y'all. - person who thought they could use a iPhone 5s screen on a iPhone 5.
Score 1
Add a comment
Can i use ip5 volume button ribbon into ip5s?
Add a comment
Can I put a iPhone 5 screen on my iPhone 5s if I put my home button onto the iPhone 5 screen
Add a comment
We thought that both are same model (a lil difference)and we can replace screen of iPhone 5s with the iPhone 5 screen.
First of all, both the phones have different power cables attached with the screens.
Moreover, in iPhone 5s there’s fingerprint either of button so it will not set on it properly.
Answered by: Faadee
IG: iamfaadee
Add a comment
Add your answer
Sanchez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 109
All Time: 184,931
