What is the best tool to use for the standoff screws?
the bloody standoff screws in the iphone 4 are so hard to find a good fitting tool for! What is the best tool that someone has found to handle the standoff screws???
I take a small Phillips and grind it down flat and that allows me to have connections at all 4 slots. I find the flathead slips out a lot and harder to put back in with flathead.
Excellent solution. This really works.
You can find all the repair tools on ifixit. You can see the iPhone 4 tear down and can see the tools.
Very small slotted (flat) head screwdriver.
1.5mm flat head has been my preferred choice
Since you asked this question, iFixit added a special standoff bit to their tools catalogue.
iPhone Standoff Screwdriver Bit (Item code: IF145-343-1)
I use a 'STANLEY 63-310 U.S.A.' pocket slotted screwdriver for this task. It is good, though not perfect: its blade is just slightly wider than screw head, so it will collide into nearby components. I need to slide it slightly after every half turn, so it overhangs clear/free area, instead of overhanging populated area and bumping into parts.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,713
1 Comment
Here you can find different market reports about tools-
https://www.factomarketinsights.com/
by Mark Johnson
