The first iteration of Studio Beats headphones were manufactured by Monster in 2008. They are available in a large variety of colors. Screwdrivers, plastic opening tools, and possibly a soldering kit may be required for repair of this device.
41 Questions View all
Can I fix the cracked headband on my beats studios?
The top plastic part of the headband on my headphones cracked. I tried to fix it with superglue, but that did not fix the problem and the headband now looks tacky. Is it possible to buy and install a replacement headband? If so, how do I install it?
They are a pair of black first generation Beats Studios.
Thanks! (:
This isn't the best pic of the crack, but here is what it looks like:
Score 12
6 Comments
Garrett Reed, post an image of your damage (repair) so we can see what you see.
by
how do u fix a broken beats
by
A friend broke my Dr dre beats studio headphones, he broke the right part, the part above the place it says "studio", what can I do to fix it.
by
buy new case i think will fix all the Problem XD
by
i have the latest beat studio metallic sky and the part where it says studio on the left side and...what should i do
by
Show 1 more comment
Add a comment
Chosen Solution
Hey Garret,
I have found a headband replacement guide for your Beats Studio. Please click on the link below to follow the step by step guide. Hope this helps.
Beats Studio First Generation Headband
Score 3
3 Comments:
Most of the Studio 1 headbands are hard to find on the market since its an older product. I had a company fix mine for $60 or so. Fast turn around time. Found them on google. "Joe's Gaming & Electronics"
by
What about Beats Studio 2.0 wireless?
by
joe stop promoting your overpriced services
by
Add a comment
If you cannot afford replacement parts we repair headbands at fixmyheadphones.co.uk
Not a sales pitch, just thought we would mention it.
Score 3
1 Comment:
My son broke his beats by dre limited edition. The whole ear piece is disconnected. Is there any way to put the wires back together and get new head band for it or something???!!
by
Add a comment
Yes. Replacement parts can be bought here. See the repair guide for the headband for a step by step explanation of how to replace it.
Score 2
Add a comment
open the headband and put a metal plate inside. use superglue..let the glue dry for 24hrs.. i manage to fix a beats studio v2 without having to buy a replacement.. u can use paint thinner to remove the glue residue..
Score 1
1 Comment:
my beats studio 2.0 fell and the headband got broken...please can you send me pictures of your headband to my gmail...efenedokeno@gmail.com...i will really appreciate it...thank you.
by
Add a comment
open the headband and put a thin metal plate inside linking the crack.. use superglue..leave it to dry the glue for 24hours.. clean all the surface that needs to be glued with paint thinner and immediately after you finish to remove the excess residue outside the headband.. i manage to fix a studio v2 making it look like it never broke.
2 Comments:
is there anywhere i can buy a plate like this? i lack the tools to cut a piece of metal to fit. i bought these headphones used because the original owner was tired of replacing the band, i saw the band and replacements crack several times within the course of a year
by
The tools are t5, and a flat head screwdriver. I had mine fixed by JoesGE.com.
by
Add a comment
My beats broke to like an inch away from the hinges and I have no idea how to fix it. Can someone please help!
2 Comments:
This usually means you need a headband repaired. Joe's Gaming & Eletronics fixes this issue for $60. Email us if you need more support sales@joesge.com
by
Yes you can Hana. Rather than trying to plug my business like the above response you can follow some guides on the internet. It's not easy and it is best to buy a new replacement headband. If you are going to fix it yourself and you are struggling for help email me here admin@fixmyheadphones.co.uk and I can help you further. Good Luck it's probably the hardest task to perform on a set of headphones apart from diaphragm work and hair thin copper stranded wire work.
by
Add a comment
can i just get a new pair of beats studio wireless because it cracked where it says studio and isn't there a way to just get a new pair. like the insurance on there.
2 Comments:
They don't offer insurance on thing you break only on manufacture flaws.
by
It IS a manufacture flaw when something breaks that's not mishandled, abuse and shows no signs of impact.
by
Add a comment
NEVER use superglue to try and fix these. From all the Beats customers send into our repair center., the ones that have been super glued cause issues. Theses issues range from destroyed hinges or glued in wires which just cause more hassle. Currently the headband repairs aren't too expensive. Studio 1 headbands are $60 and Studio 2 headbands are $70 to repair. You can send them into Joe's to get repaired within one day. https://www.joesge.com/pages/fix-beats-b...
1 Comment:
Is there anyway to fix a big crack in my beats solo 2 headband
by
Add a comment
I had a broken headband before .. i replaced it with a new one .. one year later it has been broken at the same place the previous was broken .. so i thought to support it with something .. i used a thin metal plates as showen in pictures .. now i have a headband i think it will never be broken.
Add a comment
Add your answer
Garrett Reed will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 123
All Time: 71,795
