Repair information for Bosch dishwashers.
39 Questions View all
Bosch dishwasher has no power
My friends Bosch dishwasher model Model Number: SHE68M05UC/50 has no power. We checked the power source with a voltmeter and it said 120. Then we follow it up and checked the on and off switch that was ok then we checked the door lock switch and that seemed ok. Then all of a sudden it had power so we unplugged it from the extension cord hooked everything back up and plugged it back in and now there is no power again. We are stumped can anyone help???
Score 1
Add a comment
Chosen Solution
does it have a sealed for life plug ? set the meter to continuity and check the continuity from the plug pins to the mains in on the machine ,if you have continuity your problem is further on !
hope it helps .
Add a comment
Most Helpful Answer
Check the wall plug with a lamp or a toaster. If no power, flip the breaker switch in your electrical panel.
Score 1
1 Comment:
Thanks for the tip but w we tried it there is power coming from the wall and we tried the breaker.
by
Add a comment
Add your answer
Jamie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 30
All Time: 11,739
