The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
73 Questions View all
replace non working camera
Internal camera not focusing. Two thread size purple haze across image on rear facing camera. Unable to focus. Front camera clear. Phone dropped often. No lense damage visible. No cracks visible. Purple haze looks like internal cracks?
Score 6
4 Comments
not working camera
by
Yes it's. My BlackBerry camera has stopped working more than a year.
by
happy if it be fixed
by
I got it fixed but now it captures low quality images
by
Add a comment
1 Answer
Most Helpful Answer
frank, I would download the BlackBerry Virtual Expert from BlackBerry World or go into Help and select Testing, which will allow you to use BlackBerry Virtual Expert without downloading it. With that you can test each feature in your BlackBerry Z10. Check both of the cameras with that. Also make sure that your software is updated. If your camera should be faulty use this teardown to see what is involved in changing it. The camera is not very expensive and can be purchased from places like this as well as many others. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
frank will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,129
