Identifiable by the model number S7562, the Galaxy S Duos is a dual sim card smartphone made by Samsung.
104 Questions View all
Wifi on my Samsung s duos is not working
When I on the Wifi, it goes into light green mode and does not come into complete green mode[Which is wifi adapter is failing]
Any suggestions on this.
Tried factory re-set but still the same.
Score 95
6 Comments
i hav the same problm,,wt can i do nw,i tried so many times its nt workinngggg
by
mi wifi no funciona se daño solo me funciona con paquetes de datos
y eso no megusta por que es demasiado lento
by
My WiFi connection is on but connecting any network does not connect and shows saved &secured
by
My wifi Didn't even turned on.
by
mobile does not support jiofi hotspot after connecting it show saved and secured but nothing work on it. plz help me why this is happening
by
Show 1 more comment
Add a comment
Most Helpful Answer
Dear All,
Wi-Fi Freezing fault may occur due to 10% of Wi-Fi driver related issue and 90% of WiFi hardware fault,
Simply you can use hot air flow to U204 module and check whether it's functioning back to normal
other wise you will have to repalce new U204 Wi-FI + BT module
Here you can find parts for repair
Note : BGA reworking skills required to replace WiFi module
Hope you will be able to fix the fault your self.
Cheers!
Score 5
Add a comment
Update (09/05/2016)
Score 3
Add a comment
wifi not torning on way
Score 2
Add a comment
dail*#*#526#*#* on your phone keypad this will show a message driver software sucessfully installed than try to turn on wifi this will turn no easily
Score 1
3 Comments:
It's not working.. can u please suggest me any other solution. .
by
it's not working ...... can u plz give another way to solve this problem ...
by
It is not working and can you please any other way to solve this problem
by
Add a comment
when we on the wifi the siginal ra not displayed on the screen what we should do for that
Score 1
Add a comment
is it your own WiFi signal if it is, is it been set with a password for protection preventing other users connection to your signal?
Update
Usually if it's able to pick up the wi-fi network but does not want's to connect is usually with the secuirity settings. you can try by deleating that as you defalt network and the se-activate it (try to reconnect to it) the default proiblem is usually the security settings.
1 Comment:
the same problem occurs on not protected wifi..
by
Add a comment
yes same my problem on my device
Add a comment
sumsung s 7562 wifi not working
Add a comment
Yes me too...its feel so annoyed
Add a comment
all site are open with wifi but not download any app my phone with wifi
Add a comment
Try. *#0011# > Menu key > Select Wifi > Select Power save button Off
Thanks
1 Comment:
Tried this but not working
by
Add a comment
samsung s duos wifi not turning on
1 Comment:
by
Add a comment
How to connect wifi adapter
Add a comment
you should heating wifi and bluetooth ic and reboiling it or change it
https://www.google.com.eg/imgres?imgurl=...
Add a comment
Wifi on my Samsung s duos is not working.
Add a comment
my samsung 7582 wifi is not waking
Add a comment
why i cannot turn on my wifi in samsung galaxy duos?
Add a comment
I have also same problem....
Add a comment
it no working alwayas on and low green
Add a comment
My s duos i droped it in water then i put it in rice for a few days then i turn it back on everything worked except wifi and it was on low green. Before the water incident it was perfectly fine
Add a comment
This is my problem of my Samsung phone
Add a comment
My samsung duos mobile wifi not start
1 Comment:
Big ass big
Hgcgjnncgnngcfhjk
by
Add a comment
My samsung mobile wifi not start
Add a comment
Add your answer
Sandeep will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 48
All Time: 77,776
