The UP! Plus 2 is a 3D printer manufactured by PP3DP for home or professional use and is capable of printing objects of up to 140W x 140D x 135H (mm).
3 Questions View all
Printer that is not initializing correctly and skipping?
I've had my printer for a while now, and I've run into an issue where my printer will start skipping and pushing it's y-limit boundary. There is no "click" of the switch in the back.
Score 1
Add a comment
Most Helpful Answer
If your printer is going too far back and there is no audible click then your y-limit is malfunctioning. This means your mechanical limit switch is either not connected or malfunctioned and should be replaced.
Score 1
Add a comment
make sure the firmware is updated and check the bed range settings in your slicing software.
Add a comment
Add your answer
Spencer Jefferson will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 6
All Time: 334
