The Microsoft Wedge Touch Mouse is an ambidextrous computer mouse released by Microsoft.
1 Questions View all
Stuck at step one
I had a corroded battery and need to clean the contacts. This post has detailed steps but I can't get past step one.
The cover just will not come off. I can easily pry up the edges but it feels like there's something in the middle of the top plate that's attached and I don't want to break the mouse.
Step one mentions about moving the pick tool along the edge towards the battery cover and mentions a pin I believe. This just doesn't seem to work and I don't know what to do next.
Add a comment
1 Answer
Most Helpful Answer
Steve,
That would be a cable which is connected there. It has enough length that you should be able to separate the two covers if you do it firmly/gently/controlled. Just realised your questions is from 2014. Hope you figured it out.
Score 1
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 396
