The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
800 Questions View all
Why is my kindle fire hd having sound but no picture?
My kindle fire HD has sound and I can hear noises coming out of my kindle. However my screen is showing no picture comeing through? How can I fix this as restarting is doing nothing to help my kindle fire?
Score 12
6 Comments
i have same problem. did you find a solution?
by
i also have the same problem...did u find a solution yet
by
aaron81182 I was wondering if you got your issue fixed? Please see my reply about how I fixed it.
by
Mine just started doing this like 3 days ago and I CANNOT figure it out!
by
I did the 40 second hold on the power button and it worked
by
Show 1 more comment
Add a comment
Most Helpful Answer
I watched the you tube video. Held the power button for at least 40 seconds and screen came back!
Score 5
5 Comments:
Wow...I was very skeptical but this worked!
by
Genius! Thankyou.
by
Unbelievable.....IT WORKED......THANK YOU
by
It worked, thanks so much for posting!
by
I was a little leary to but it worked
by
Add a comment
katie, since you have nothing showing on your screen regardless of what you do, I would suggest that you use this guide. Check to make sure that your LCD is properly connected and that you do not see any obvious damage to the cable and any of the components on the board. It is possible that you have a bad LCD (or bad backlight), replace it and let us know what you find.
Score 3
Add a comment
I had the same issue and Amazon was no help. I had to take the back cover off and unhook the battery. Next you re-hook the battery and the kindle started working. I had to re-set everything-clock, wifi, etc... but at least it's working.
Score 3
1 Comment:
This is what helped with the issue mine had.
by
Add a comment
Tried all the above, unconnecting and reconnecting the battery, holding down the power button, nothing works, the light is coming on the screen but there are no images, my son put it to charge and that happened.
Score 2
1 Comment:
Me too Pamela. Nothing has resolved it. Any updates?
by
Add a comment
My kindle fire has sound the screen is black. I’ve also un-hooked the battery several times. Thought I had it on the first try, nope. I have a full charge on it cause the screen comes on for a spilt second then goes back to black. Tired holding the power button for 20, 30, 40,50 seconds still doesn’t give me a functioning screen. About ready to call it quits. This happen about 4yrs ago and thought just maybe nope still doesn’t work.
Score 1
Add a comment
my amazon tablet is not working but it just making sound but no pictures can you help me fix it
Score 1
Add a comment
Mind is the relevant get my back of
Add a comment
Add your answer
katie will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 30
All Time: 22,636
