Krups single trigger coffee grinder identified as style F203.
11 Questions View all
motor works but blades only spin if grinder is unloaded
The machine seems as if it's working with no load or with very small amount, but as soon as I put in a normal amount of material to be ground then the blades do not turn. It's like whatever connects the blades to the spinning shaft has failed or does not engage properly. Also how do I get the blades off?
Score 3
1 Comment
The blade screw is stripped. I have the same problem. I can’t find a replacement blade.
by
Add a comment
1 Answer
Chosen Solution
the blades can be pulled off, pull hard,because the thread inside the plastic blade hub has stripped. Penny pinching on Krups part! you will now have to glue the blade back in place-epoxy resin worked for me.
Score 2
1 Comment:
Worked a treat, many thanks.
by
Add a comment
Add your answer
tanya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 2,568
