A business-class desktop PC, sold in multiple form factors and configurations.
17 Questions View all
when I press the power button nothing happens.
There is an led on the MB indicating that it has power but when i press the power button nothing happens. All the cables are connected and there is no visible damage to the motherboard and other components.
Score 5
Add a comment
I would check power cord first...then check the power connection
Add a comment
Hi guys, I have the exact same problems. I have checked the psu and power connectors, and the front card power button, they are all fine. The bios chip gets really hot though.
What can I do?
thanks
1 Comment:
my guess would be electrolytic capacitors in the power supply are going bad
purchase another similar P.C - put your hdd & ram in it - doesnt cost much
by
Add a comment
Replace the motherboard. It'very easy. While doing that add 3.8 processors and AMD 5450 video board. Put all 4 gigs of memory. Add 1 terabyte hard drive. Install Windows 10 and you,'ll have a nice running computer. But the motherboard alone will solve your problem, You can get them cheap on EBay.
Add a comment
I’ve had the same problem and I have a answer for it. There should be a green pin inside and if it’s on the “RTCRST” pin move it to the “PSWC” pin and that will work.
Add a comment
Brother this is problem of your front Power panel card unplug the front button power card and on PC directly or replace front card of power!
Score -1
Add a comment
check processor chips
Score -1
Add a comment
Add your answer
Joran Geeraerts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,805
