The Infiniti Pro Hair Dryer by Conair was released in 2013 as a salon performance AC styling tool. Infinity Pro is equipped with a light and powerful AC motor. Other features of the Infinity Pro are its true cold shot button, its concentrator and diffuser attachments, and its 3 heat and 2 speed rocket switches. The hair dryer comes in the colors orange or violet.
6 Questions View all
Why is my air spin hair styler slowed down?
what happened:
My hair dryer-brush— an Infiniti Pro Conair Hot Air Spin Styler— used to spin at a high speed, but it slowed down recently.
what I did:
I opened the device, there was no hair clogged.
But the rotor did not spin fluently. Even it couldn't be spinned manually.
I tried to put some oil near the both ends of the rotor, it was of no help.
I couldn't remove the element barrel,as everything was pressed. Therefor I couldn't expose the rotor from the base.
What I want to ask:
How can I fix it's slowing down?
Thanks
Score 2
Add a comment
Chosen Solution
neissa1982, could be caused by seized brass bushings. For that you will have to remove the motor and take a look at the stator and the shaft bearings.
Score 1
1 Comment:
How do you take it apart?
by
Add a comment
The brush slows down and I cannot use it in the proper way. How do I fix this problem. I threw out the box and it is less than a year old. Please help. Thank you.
Add a comment
Add your answer
neissa1982 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 26
All Time: 6,377
