Repair guides and support for phones manufactured by Lenovo.
287 Questions View all
The phone mention me android is checking file system while restart
*cannot on the phone
  • always mention me "android is checking file system " and "abnormal shutdown , checking file system" while restart the phone and mention me again with the same word until the battery die.
Lenovo Phone A388t
Score 39
7 Comments
My phone always ..shutdown..please help me
by
andriod is checking file system abnormal shutdown file cheking system a338t please help me...
by
huawei y336 uo2 andriod checking abnormally file system pls help me..
by
my phone is only mention android on display continue. Is there any solution?
by
I have lava iris x1 . Same problem
by
Show 2 more comments
Add a comment
Most Helpful Answer
That's the phone rechecking to make sure all your files are there and everything is good. It happens when you power it off wrong sometimes or the device looses it's battery for a period of time.
Hope that answers your question!
Score 8
5 Comments:
UNTILL shutdown it says again n again
by
How do i fix it. It annoys me
by
My phone is..always restart ....
Please help me..
by
thanks its work
by
We have to be careful with the apps we install especially the core ones like Applock apps. Some of the poorly designed ones make phones restart overtime.
by
Add a comment
You all must consult any phone repairer! Your android data may have been corrupted due to some virus or anything like that
Score 2
Add a comment
I have been having the same problem but I have realised that the "power off app" I had has been the cause of that. I just uninstalled the app and now I switch off the phone normally. U can try it out if you have the same issue.
Score 1
1 Comment:
How are we meant to do that if our phones wont switch on
by
Add a comment
hard reset your phone. google it. it worked fine with me. but u gonna lost all data. like new phone.
Score 1
1 Comment:
But ive tried it many times and it dosent work
by
Add a comment
Mine, happened the same way while I'm in our church this afternoon, my phone has a built-in battery so there is no way that I can shut it down ferociously, with that I restarted it and I pressed the off button while under checking time causing my phone to restart of course. But then it, happened again.. then I did the same thing.. the 3rd time, but before it restarts "I pray to God that it may be opened for I really need it and what would I do if I lose it." Then after ending the prayer I hid my phone to may bag, leaving and trusting it all to God.
Then guess what? mine works well now.. hehe :) You just have to be reminded that you should trust and ask Him. :) He always listens.
Score 1
1 Comment:
by
Add a comment
GO TO ''hard reset option then click on delete all user data then reboot your phone and leave it for 1/2hr and change you battery and while charging use authorised charger '.That's all you are done
Score 1
1 Comment:
No.Nigga.It.Won't.Work
by
Add a comment
I think your device might have detected corruption in its internal memory/SD card and trying to correct them to prevent damage to the OS. try removing the SD card and see if this issue persist, if it does, then the internal memory is the culprit.
you wanna try these if you have advanced computer knowledge:
(phone must be rooted)
https://forum.xda-developers.com/showthr...
keep back up copies of your files.
Score 1
Add a comment
abnormal system checking problem
Score 1
Add a comment
WiFi not working and Bluetooth not working rear camera not working
Add a comment
Full charge
He is not full charge
Add a comment
Add your answer
ashleybeben will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 18,784
