Eighth generation of the Mazda Protege.
49 Questions View all
What are the symptoms of a weak ignition coil?
Why does my 1999 Mazda protege 1.6 hesitate to go when i accelerate immediately after any immediate stop? Is it something to do with ignition coil? I did hear a spark noise from the ignition coil area when i checked. Please advice me.
1 Comment
Thank you guys... Coils and new NGK iridium spark plugs on its way.
by
Add a comment
Chosen Solution
The symptoms of a bad coil are misfire or backfire,engine stalling, hard starting and smelling fuel while trying to start, bad fuel mileage and not starting at all. If you are hearing a sparking coming from your coil its more apt to be bad ignition wires .I would start by checking plug wires and boots Hope this helps
Score 2
Add a comment
Most Helpful Answer
Weak coil will cause miss firing and hesitation.
Score 2
Add a comment
Add your answer
Vishnu will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 3,448
