Toy quadcopter with camera, controlled over Wifi by smartphone.
23 Questions View all
Why is my drone is not creating wifi hotspot to connect?
In my parrot ar.drone its just showing red light in all four corners and is not creating wifi hotspot to connect with remote. if any one could help me with this solving.
Score 18
24 Comments
No wifi connection on my jxd 528 drone ..i use galaxy note FE..anyone can help to solve it?
by
Hello I was using Free fly 3 & I was making with thee setting & hit 24hz & 60hz then it say All I hit all & now no wifi signal
by
Just reset the drone :)
by
Some one please answer that
by
My drone doesn't have a rest button just a camera and the battery and on off switch.....
by
Show 19 more comments
Add a comment
Most Helpful Answer
Try to fully charge the battery. Once you have done this on the AR Drone push the un-pair button then push the 'reset' button and place the AR Drone on a flat level surface and unplug the battery. On the iPod/device go to the WiFi menu tap on the AR Drone and select 'Forget this device'.
Reconnect the battery on the AR Drone and wait for the leds to go green.
Put your iPod into Airplane mode, switch on the WiFi and try to reconnect to the AR Drone.
If the led's on your AR Drone are green and you are still unable to connect can you try resetting your iPod/device .
You might have it on access-point mode, which is for Android users like me, i had the same problem and turned out it was on Ad-hoc mode, which is for Apple users. Hold down the unpair button for 5 sec. The LEDs flash red when access-point mode is switched to ad-hoc mode. The LEDs flash green when ad-hoc mode is switched to access-point mode
I've also read that wireless camera systems can interfere with the signal.
AR Drone help desk said that the all red on all 4 rotors means there's a problem on the main board.
hopefully you get them running again, Good Luck!
Score 3
4 Comments:
by
my drone lh- x12wf wifi not work how to fix
by
i have.....( connect,no internet). issue. all green lights after self check, full battery and its brand new out the box. can anyone help me ,and this is my first one . its been put up for 3 years never opened tho .
by
this not give you internet connection if shows connect you are good
by
Add a comment
You reset it by pressing the reset button which is under the battery, where's the unpair button?
Score 2
Add a comment
The reset button is under the little hole under the battery. Try a touthpicker to reachs the button.
1 Comment:
Use a toothpicker to push the reset button. (little hole under the battery)
by
Add a comment
Ls_e525 drone wifi show but not connecting
Add a comment
Add your answer
akashgarg13 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 133
All Time: 95,648
